Talk:VertX
Revision as of 21:53, 21 January 2012 by Emmanuel (talk | contribs) (moved Talk:X-carriage-struder to Talk:VertX: needed to do that since this name was preferred to x-carriage-struder :))
- ABS print temps- it should also be easy to attach a shield made of aluminum or thin copper. I'm thinking something like one side of a roof, inverted. or in ascii: \
This would deflect the hot plume around the plastic, so the main source of heating of the carriage would be conduction up the hotend body.--Buback 15:50, 31 August 2011 (UTC)
distance between the z rods
The wiki says that the distance between the z rods is 30 mm, but in the stl-file the distance between the holes seems to be 28,5 mm. Could you update the stl-files or do I have to tweak them alone to make them fit on my printer?
- Alfons
