ToyREP Buyers Guide
ToyREP Documentation
This page is under construction!
Introduction
BoM
Parts for default set-up with embedded 111x78x36mm big PSU, Arduino Mega 2560 with RAMPS 1.4, 100x100x100mm big print volume, short throw geared extruder for 1.75mm filament with E3D clone hotend, 120x120x3mm polycarbonate sheet as cold bed.
Plastic parts
Rods, Screws And Nuts
Picture | Quantity | Description | Comments |
3 | M8x255mm Threaded Rod | Alternatively 265mm long for PSU2 and/or 125x125mm print area or 240mm for printer with 100x100mm print area and without PSU. | |
2 | M8x245mm Threaded Rod | Alternatively 265mm long for PSU2 and/or 125x125mm print area or 230mm for printer with 100x100mm print area and without PSU. | |
4 | M8x170mm Threaded Rod | Alternatively 180mm long for PSU2 and/or 125x125mm print area or 155mm for printer with 100x100mm print area and without PSU. | |
2 | Ø8x225mm Y Axis Smooth Rod | Alternatively 245mm long for PSU2 and/or 125x125mm print area or 220mm for printer with 100x100mm print area and without PSU. | |
2 | Ø8x295mm Z Axis Smooth Rod | ||
2 | Ø8x245mm X Axis Smooth Rod | Alternatively 255mm long for PSU2 and/or 125x125mm print area or 230mm for printer with 100x100mm print area and without PSU. | |
1 | Ø8x15mm Idler Smooth Rod | ||
2 | M5x250mm Z Movement Threaded Rod | ||
1 | M3x90mm Threaded Rod | Z endstop distance
50 | M8 Hex Nut | ||
80 | M8 Washer | Additional washer are used to set correct distance between plastic parts. The amount can vary. | |
2 | M6 Mudgard Washer | On top of 624ZZ bearings
2 | M5 Hex Nut |
2 | M4x20mm Round-pan Screw | For 624ZZ bearings | |
4 | M4x50 Countersunk Screws | For frog and geared extruder | |
6 | M4 Hex Nut | ||
6 | M4 Washers |
3 | M3X10 Countersunk Screw | For PSU installation | |
4 | M3x20mm Countersunk Screw | ||
8 | M3 Hex Nut | ||
4 | M3 Nylock Nut | ||
1 | M3 Washer |
9 | 3X13 Round-pan Wood Screw | PSU Cover and X, Y, Z, E Motor instalation | |
6 | 2.5X10 Round-pan Wood Screw | X, Y, Z endstop installation |
Bearings, Belts, Motors
1 | T2.5x500mm Timing belt | Alternatively 520mm long for PSU2 and/or 125x125mm print area or 470mm for printer with 100x100mm print area and without PSU. | |
1 | 28BYJ-48 Stepper Motor | Length of wire c. 850mm | |
1 | E3D Clone | With 12V 40W ceramic heat cartridge and 100k Ohm thermistor, length of wire c. 950mm | |
1 | 40x40x10mm Fan | Small 12V fan, length of wire c. 950mm | |
3 | 608ZZ Bearing | ||
1 | M8 Hobbed bolt | for eg. Hyena hobbed bolt. | |
1 | 1.8m Power Supply cable with plug | cca 1.5-2mm long PC cable would be just fine - cut of the computer Euro connector, keep power socket plug. | |
1 | 200mm Dual Line cable | Should be able to withstand at least 12V 4A, Insulation with two colours to distinguish +12V and -12V | |
1 | Power supply switch (250V, 1A) | Installation into panel with mounting hole 13x19mm | |
4 | Ø6mmx25 Heat Shrink | ||
1 | Cable Tie | ||
2 | 28BYJ-48 Stepper Motor | Length of wire c. 120mm and 180mm
1 | 624ZZ Ball Bearing |
1 | 28BYJ-48 Stepper Motor | Length of wire c. 250mm | |
1 | Micro Switch | Mounting holes Ø2.5mm 11mm apart, length of wire c. 300mm
4 | LM8UU Bearing | ||
8 | Cable Tie |
1 | 28BYJ-48 Stepper Motor | Length of wire c. 500mm | |
2 | Micro Switch | Mounting holes Ø2.5mm 11mm apart, length of wire c. 850mm | |
7 | LM8UU Bearing | ||
1 | 624ZZ Ball Bearing | ||
1 | T2.5x480mm Timing belt | Alternatively 500mm long for PSU2 and/or 125x125mm print area or 450mm for printer with 100x100mm print area and without PSU. | |
2 | Ø8/5x20mm PVC Tube | ||
14 | Cable Tie |
1 | M8 Nylock Nut | ||
4 | M8 Washer | ||
2 | M4x50mm Round-pan Screw | ||
2 | M4 Hex Nut | ||
4 | M4 Washers | ||
2 | Ø7/5x15mm Spring | ||
4 | M3x35mm Round-pan Screw | ||
2 | M3x30mm Countersunk Screw | ||
2 | M3x25mm Countersunk Screw | ||
4 | M3x16mm Round-pan Screw | ||
2 | M3 Nylock Nut | ||
1 | M3 Hex Nut | ||
4 | M3x12 Hex Nut | If long hex nut not available glue into each hole of fan mount two M3 nuts. Keep them apart. | |
7 | M3 washer | ||
2 | 3X13 Round-pan Wood Screw | ||
10 | Cable Tie | ||
1 | 120x120x3mm Polycarbonate Plate | Mounting holes in corners 105x105mm apart. Bigger bed is 145x145x3mm with mounting holes 130x130mm apart. | |
4 | Ø7/5x15mm Spring | ||
4 | M3x25mm Countersunk Screw | ||
8 | M3 washer | Eventually M4 Washers
