Tripodmaker
Release status: unknown
Description | End of life documentation
License | None
Author | |
Contributors | |
Based-on | |
Categories | None
CAD Models | |
External Link |
As of December 31st 2017 - Tripodmaker ended their production and support.
All support documentation can be found here.
Manual Tripodmaker Classic
01-00f-tripodmaker-manual
Manual Tripodmaker Black Edition
Tripodmaker_Black_Edition_User_Manual_slides_new_firmware
Cura installation info for slicing
Cura set-up for Tripodmaker
Additional Windows software:
setuprepetierhosttripodmaker_1_0_6
Printrun
Additional Mac OS X soft ware:
Printrun
Netfab for mac:
netfabb_studio_basic_for_mac
Components to print
door knob and black edition v2 print head cover
Trouble shooting
Cable Connectivity check – in case you have trouble with the USB connection of your printer.
Cold zone inside Heat break is clogged – this is the method for unclogging your nozzle
Cold pull – use this method for removing debris from your nozzle.
Door mounting – how to mount the door
Extruder drive cleaning – how to clean the extruder drive after grinding – do this once very 50 hours of printing
Logging your Tripodmaker – In case you have issue’s and we need info
Heater block and thermistor – Hot end repair info
Screen issue – In case your screen or button is not working
Screen replacement – In case we need to replace your screen
Thermistor replacement – In case your nozzle temperature read-out is wrong or fluctuations are too high.
