Tripodmaker
Release status: Working
Description | End of life documentation for Tripodmaker.
License | None
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | None
External Link |
- 1 Tripodmaker Stops its business
- 2 WE ARE SELLING OF OUR OLD STOCK
- 3 All support documentation can be found here.
As of December 31st 2017 - Tripodmaker ended their production and support.
We have a limited ammount of devices left of our Tripodmaker v3.
Prices:
- Retail price: 2500 euro excl. VAT
- Current price: 999 euro excl. VAT
- If you order multiple devices, we might drop prices even further.
Terms for these devices:
- No support
- No service
- No warranty
- No shipping price included (please ask for a quote)
Interested in a device? Reach out to info[at]tripodmaker[dot]com with "BUY BLACK EDITION V3" in the title and we will get back to you.
SPECS:
HARDWARE | |
technology | FDM (Fused Deposition modeling) |
dimensions of printer | 42 cm x 53 cm x 101 cm |
print area | Ø 25 cm x 42 cm |
nozzle | Ø 0.4 mm; full metal - up to 295°C |
heated bed | up to 100°C |
power | 88 - 264 V; 47 - 63 Hz; 5A |
MATERIALS | |
diameter | 1.75 mm |
plastics | PLA; PETG; HIPS; ABS; Polycarbonate |
SOFTWARE | |
software | Open source |
PERFORMANCE | |
bed leveling | full automatic; with possible screw assist |
layer thickness / resolution | 75 micron - 300 micron |
machine tolerance | 0.1 mm |
Manual Tripodmaker Classic
Manual Tripodmaker Black Edition
Cura installation info for slicing
SET-UP PARAMETERS
Machine dimensions
dimensions | Tripodmaker Classic | Tripodmaker Black Edition | Tripdmaker Black Edition with doors | Tripodmaker Black Edition v2 |
X (width) [mm] | 300 | 300 | 200 | 200 |
Y (depth) [mm] | 300 | 300 | 200 | 200 |
Z (height) [mm] | 390 | 450 | 450 | 420 |
Other specifications
- Build plate shape: elliptic
- Heated bed: checked
- Machine center is zero: checked
- Gcode flavor: Repetier
- Printhead settings and Gantry height: Leave as is
- Nozzle size: 0.4mm
- Material diameter: 1,75 mm
Start code
;Home G28 G1 X0 Y-100 Z030 F5000 ;Prime the extruder G92 E0 G1 F200 E30 G92 E0
End code
;Turn off temperatures M104 T0 S0 M140 S0 ;Retract the filament G92 E1 G1 E-1 F300 G28 X0 Y0 M84
PRINT SETTINGS
Infill
- Hollow: 0 percent
- Normal: 10 percent
- Strong: 25 percent
- Solid: 100 percent
Material settings
materials | ABS | PLA | PET | Wood | Flex 45 | ASA |
Volume flow 0,4 mm nozzle [mm3] | 2,4 | 3,5 | 2,4 | 3 | 0,9 | 2,4 |
Volume flow 0,8 mm nozzle [mm3] | 4,8 | 7 | 4,8 | 6 | / | 4,8 |
Print Temperature [Celcius] | 255 | 215 | 230 | 215 | 260 | 260 |
Bed Temperature [Celcius] | 90 | 60 | 70 | 60 | 0 | 90 |
Retraction Retract Speed [mm/s] | 25 | 25 | 25 | 25 | 25 | 25 |
Retraction Prime Speed [mm/s] | 25 | 25 | 25 | 25 | 25 | 25 |
Retraction Amount [mm] | 2 | 3 | 3 | 3 | 0 | 3 |
Retraction Hop [mm] | 2 | 0,075 | 0,075 | 0,075 | 0,075 | 0,075 |
Speed top/bottom [mm/s] | 20 | 20 | 20 | 20 | 15 | 20 |
Speed bottom layer [mm/s] | 20 | 20 | 20 | 20 | 15 | 20 |
Enable print cooling | No | Yes | Yes | Yes | No | No |
Speed settings
Normal speed
These settings are the fastest possible settings to maintain a print that finishes for 90 percent successfully. Printing slower will result in better finish and better reliability.
Normal settings from Prisma are 60 percent of the fast settings.
Fast speed
Infill speed [mm/s] = volume flow [mmˆ3] / layer height [mm] / nozzle size [mm]
- Outer wall speed [mm/s] = 0,6 x Infill speed [mm/s]
- Inner wall speed [mm/s] = 0,6 x Infill speed [mm/s]
- Speed top and bottom [mm/s] = 20mm/s
- Support infill speed [mm/s] = 0,6 x Infill speed [mm/s]
- Support roof speed [mm/s] = 0,6 x Infill speed [mm/s]
Example
PLA on 0,1 layer height and with 0,4 mm nozzle:
Fast Infill speed = 3,5 mmˆ3 (volume flow) / 0,1 mm (layer height) / 0,4 mm (nozzle size) = 87,5 mm/s fast speed Other speeds: 0,6 x 87,5 mm/s (Infill speed) = 52,5 mm/s
Normal Infill speed = 52,5 mm/s x 0,6 = 31,5 mm/s Other speeds = 18,9 mm/s
Additional Windows software:
Additional Mac OS X soft ware:
Netfab for mac:
Components to print
Trouble shooting
- File:Cable Connectivity check – in case you have trouble with the USB connection of your printer.pdf
Calibration of your device
ATTENTION: DOING THIS WRONG WILL RESULT IN A BAD CALIBRATED DEVICE
Only Black edition models equipped with an inductive sensor can use this technique.
if you screw up, your device is lost and you are on your own
