User:Axs5327
About Anil Senturk
Mechanical Engineering junior working on the OS3DP project, AKA EDSGN 497D. I think I'm the only international student in my section. I'm hoping to learn alot more about this project so that maybe in the future I can introduce this open source technology to Turkey and its surrounding countries.
Good luck to all fellow classmates.
PSU email
BLOG 8
I am not suprised by this patent trolling company that just took action about protecting many 3D designes against illegal 3D printing, it makes sense to create such a patent as these days we are seeing several companies like makerbot or form1 succesfully develop affordable 3d printers. However right now a company isn't forced to use this funny 3D printing DRM patent. Just like many other protection laws/patents etc I am pretty conviced that as long as there is a strong open-source community, people will not let this DRM situation ruin our freedom of creating 3D printable objects. Also we haven't seen or heard of any type of software protection made available for regular paper printers of photocopying machines, although a 3d printer has an advatage of creating an object, this DRM will not be successful as it defies the primary purpose of using a 3d printer. In my older blog I gave a few examples of failed copyright situations, if this patent gets implemented, people will be able to hack 3d object or at least replicate them using 3d scanners or making an identical copy on CAD software. It's funny seeing a few patent trolls trying hard to establish a system that kills the primary purpose of using the printing.
BLOG 7
1) Since the primary prupose of a 3d printer is to enable the user to create an object that they may need, this interesting development would enable us to print parts that are more useful, not just parts to be used for construction of display purposes but lights sensors, motion sensors and imaging. Someone could create anything that uses light optics using these printers. This technique can also be used in billion dollar industries to reduce the costs of simple components, plus the material used are photopolymers that could make components much more environmentally safe by avoiding the use of metals such as mercury.
2) Disney engineers have used the more advanced Stereolithography technology rather than the Fused deposition modeling that we use in our 3d printers. This technology uses lasers to print object in much higher resolution that enables the objects to have such little lights gaps. The FORM1 3d printer that is around 2200$ also uses this technology that is a little different from the ones that we use in our labs, and they have attained printing resolutions of around 25 microns. However I think the advantage of using fused filament technology is the cost of production and the easiness of creating models without using liquified resins that solidify under laser that could be messy. Since there is room for improvements, we can create extruders that could extrude thiner filaments, however we may need new material that could be extruded in such small diameters, maybe we should start searching about extrudable photopolymers. The models we use in our labs will not be able to extrude the rubber materials that has optical abilities as well. We may have to switch to Stereolithography to be able to print interactive models if the current models cannot be furthur developed into such capabilities.
3) If we can improve what Disney Engineers have found and increase the numbers of light gates and reduce the diameters of these paths, using simple optics would help us create anything. I guess we can somehow use this technique and create a more improved touchsensing technology and embed fingerprint sensing technology into one touchpad, this would be achievable by using thousands, or maybe millions of mini light paths. I would like to create an accelerometer that would require one ligth source and a little thin plastic rod integrated inside the accelerometer that would react to any kind of accelerated motion by bending and by doing that, it would transfer the light source into a different location on the sensor and then it will create an output signal of an acceleration. The rod would look like a fiber optic material inside a cube, and in motionless state it would point the light to the center, any distrubance or motion would bend the rod which would make the light point into another part of the the light sensor, the distance the light travels from the centre point would be used as a reference to calculate acceleration.
BLOG 6
1) There has been developments in producing different kinds of cells that would create different kinds of tissues.I believe that Organovo is using these kinds of cells and use their bio 3D printer to give them proper shapes that could be used by pharmaceutical companies for better research or to provide patients that may need regenerative treatments. In the existing research, stem cells are modified to transform to different kinds of tissues that would take time. This technology, as far as I can interpret would make the process of building tissues a lot faster by using existing cells. So this is an improvements over the current techniques. If this company is producing their cells from stem cells, it may bring some controversy as some stem cells are obtained from embryos and it may affect its legality due to moral reasons. Otherwise there is no reason to stop science from improving our life quality.
2)I do not think that its easy to obtain living tissue cells created from stem cells, also I think that most of the REPRAP community may not be capable of conducting very complex bioengineering research, this should be beyond the capabilities of people working for an open source community. However researchers at universities or hospitals could possibly use the open source 3d printing technology to make their research efforts on this bioengineering printing technologies by adapting the REPRAP models into bioREPRAP models, hopefully.
BLOG 5
1) Since Defense Distributed has gained enough public support as they have raised more than 20000$ dollars after a few failed attempts, I would feel confident about continuing my work. Plus, its technically not an illegal act to produce weapons without violating the law, they are not intended to mass produce it or sell their ideas. I'm sure Stratasys isn't the only company that sells professional level 3d printers. They can find another company, and make sure to keep their purpose of lease secret. Or as Wilson is thinking about making Deference Distributed a company might give them a freedom of doing what they really want to do in terms of researching and producing weapons made from cheaper plastic components.
2) It is impossible to track down each individual on this planet no matter how interconnected we are through the internet and other means of communications. A printer connected to a personal computer without any world communication could print anything that it's capable of. We already are in a community that produces and distributes all sorts of illegal products and substances no matter how much regulation there is. This also applies to a 3d printer community, a 3d printer isn't actually an illegal product however it is capable of producing weapons and other similar dangerous and illegal products. I would actually support the restrictions and regulations of producing anything that could potentially harm a human being. In many civilized countries, especially in Europe it is fairly difficult to obtain a pistol license and yet they are the amongst most liveable countries in the world. Many Americans are tired of seeing new reports of people killing each other as obtaining many kinds of guns aren't that difficult. ' However as I had stated in my previous blog, I think that copyright laws and IP restricts our freedom of thinking, if we could easily distribute useful information it would serve the world community for good purposes.
3) There are other types of weapons that could be printed, knives made from hard plastic could serve a similar purpose. Any printable parts that could be used to consume illegal drugs could face some regulations. Others would include copyrighted products such as electronic components of brands etc.
BLOG 4
REPRAP started as an open source project and it's still going on, there is a huge community of contributors and many different models have evolved. However there is no current open source model that could be used by everyone, and people need some technical skills in building these machines. Almost everything we own was produced by a big company that aims profit, and in return we are using good quality products such as cell phones or computers that we couldn't build by our own easily. I think a company like Makerbot aims this, they want to popularize 3D printers by building them completely and shipping them with appropriate software that could be used by almost everyone. Makerbot isn't the only company in this business, in fact a better printer was developed by a group of MIT graduates, ("http://www.engadget.com/2012/09/26/form-1-delivers-high-end-3d-printing-for-an-affordable-price/"), this model can print layers that are 25 microns, almost 75% better than the replicator 2. As we see more models being developed by profit making companies we will see a better price range. Even if these machines are closed sourced, they can still help the open source community get ideas from these devices. I don't mind these two companies working hard to deliver a good product to everyone, I think that the idea of being open sourced makes the development process a little slower as there are many ideas floating around. As long as there are two main developers of 3d printers,ones that make money and an open source community, the 3d printers will evolve faster. These two groups have to coexist.
To give an appropriate answer about the Thinkiverse issue, I first tried searching their user terms and agreement so that I don't give a biased answer by only one article. There many websites that hosts user contents such as YouTube, twitter and thinkiverse uses the same industry practices as they are a large website. They actually give the user a license to select while uploading their designs so that others may not use the design without asking the up-loader, if necessary. And apparently Makerbot does not claim ownership of the user created content thus proving prusa wrong. I think we can still use Thinkiverse to upload any files, and if our design is a work of art, we can put a license on it so that people would be aware of the hard work done but still be able to use it. On the other hand, another fully open site could be used to share files openly without worrying about licensed designs.
You may think that I have contradicted my previous blog(rebutting IP), in this blog I think that people could still place a license on their designs on thinkiverse so that others could ask for permission and/or see the designers name on the design itself.
question(i find this more useful than spamming you): When can we start the printing service so that we can gain xp points? and lastly, we are building an ohm and you wanted us not use a part, instead there is a newer stl file, but i couldn't find it on the ohm website, http://reprap.org/wiki/Mendel_X-axis , maybe we as a group should talk to you about this. thanks.
BLOG 3
1) Since OS3DP is an open source type of development, we cannot easily predict what will happen to this technology in the future, however since there is a hard working community of thousands of people working on it, I predict that it will start an exponential growth in its development as more people start using it. Many large media companies have applied many restriction techniques in to their products to prevent people from stealing the “ideas” of the ones that worked hard on it. Sony had developed a successful protection software on their PlayStation 3 that stopped piracy, very few hackers had managed to run Blu-ray videogames from a USB drive but it was limited to a few titles and Sony quickly updated their software, and those that kept using the older software weren’t given permission to play their games online and use the PlayStation network system for a better gaming experience. Although this might prove that a multi billionaire company could win the piracy war, they actually ended up with lower sales figures of their system in comparison to their Predecessor product. So this proves the idea that something would more likely to be popular or successful if large companies let people freely scrutinize these kinds of products without the intent of damaging the economic properties company or the owners of the ideas. I would actually like the 3D printing technology to be supported by companies that aim profit. Makerbot recently announced their new printer at a retail price of 2200$, they have produced a much more complex and an advanced product than the ones we have at the labs. Branding these goods also helps it getting promoted to everyone, not just developers and contributors. I’m not sure whether makerbot would patent many of their new ideas or not but I hope that they would let the open source idea continue and help others get inspired their new machine. Since OS3DP started as an open source project, it will continue in that direction, just like Linux that started in the early 1990s and now there are many major brands that use it and still have a community of millions that support it for no purpose of earning money out of it.
2)My first blog edit “About Anil Senturk” clearly describes my objective of bringing the OS3DP technology to Turkey. If I’ll go back to Turkey for the next summer holiday, I will most likely work at a technical university as an Assistant to a graduate student. It would be my pleasure to inform those people about the 3D printing technology and possibly bring them a few samples to attract that community. There is already a large group potentially successful group of students that would definitely improve the current system.
In my personal view, someone’s success in their academic or work life shouldn’t be a measure of how attractive they are to a potential husband/wife, so my introduction of OS3DP to Turkey would be beneficial for the community itself, plus I might be known as the Bowyer of Turkey.
3)In my opinion, protecting your own ideas from others is nothing but selfishness. We start our life by learning from our parents, copying our friends and education is free and mostly affordable almost all around the world to a certain degree. I do not think that OS3DP will completely destroy IP, however it will sparkle the idea of free thinking and free sharing to many that actually work on the development, and feel accomplished when they work for a good cause without charging people just because they came up with a good idea. In my opinion the entire world would benefit from letting people share ideas freely, many people would be allowed to improve whatever they feel that needs an improvement. This might actually sound confusing, letting many people share thoughts might create a huge pool of new information but since there are many people with different levels of intellectuality, this would create a natural filter of letting better ideas being used.
question: Do we have to answer your response questions in the discussion bar?
BLOG 2-
1) We live in a world where it is almost impossible to predict the next decade. No one could have imagined a cell phone with a quad-core processor clocked at 1.5 GHz take high quality pictures and connect to extremely high speed mobile networks back in the early 2000s. So anything that we could imagine at this very moment will most likely be achievable in the future. A completely self replicating device may sound very odd but we are already in the process of building simple 3D printers that could print all of its plastic parts. I find it difficult to imagine a small device like an OS3DP extruding metal components and assembling it all alone without an external interaction. We need to achieve very high temperatures to give shape to metallic parts, finding a technology that would enable this process in a much smaller scale could work together with a plastic extruder to print every kind of part necessary. Lastly I could imagine small robotic arms and numerous sensors and a very advanced control system assembling itself. Further research needs to be done on new type of material processing in smaller scales. It may be possible to build a small robot that could assemble parts together on its own in a pre defined sets of commands. Governments and big corporations may not like the idea of building everything from cheaply available materials. Most companies earn money by putting a lot of profit on building goods and distributing them. Some people are already able to build gun components to improve current firearms as OS3DP owners could print anything they want.
2) Although wealth may just mean money and the amount of valuable goods someone possesses for many of us, it may not easily increase its value without having to work very hard. Bowyers phrase refers to the OS3DP that we have at the labs, these devices just need PLA, a few electric motors, sensors and some metallic parts. After building one, you can easily start printing more of the plastic components that you need so you actually create components without needing to buy them which basically increases your wealth without wasting alot of money. All you need to do is buy these cheap components and keep producing more of the same kind of devices which will increase the output exponentially. If these devices become very popular in the near future, we could assume that all of its users are basically entrepreneurs. Because entrepreneurship means innovation, we will not need to purchase certain goods as we have our own building device. These device currently cannot print everything, we will still heavily rely on the mass market of goods. Currently, these devices are for replicating and developing purposes and a lot more work has to be done to revolutionize the world of creating goods of your own.
3) The OS3Dp project started from only one person but now there are possible thousands that are interested in this project. There are currently websites that describe the history of this project, many free soft-wares and all CAD files are available to print any component of any model. There are many open-source projects around the world and the first one that comes up to my mind is the Linux operating systems. Many people contributed and there are now many types of Linux OSs and useful software available for free. I see the OS3DP project like this, the number of different kinds of models will continue increasing however the most stable and sturdy ones will be the focus point. Along with this, more user friendly and easy to understand websites will be available to public. For this project to be more successful I think an online catalog of PLA components submitted for donation purposes should be created, this way people could purchase these components for very low prices and some money could be made from online advertisements to cover up the costs of running the website. Unlike today, there will be a lot less variety of different models, this would be due to the development process leading to fewer better designs.
BLOG 1-
FUNNY : Admiral Ackbar got his first fame from the amazing Star Wars series. However people around the internet are pretty good at creating funny memes almost out of everything. I still smile at the pictures with the Admiral Ackbar "It's A trap" meme.
USELESS : Although this design is a little artistic it does not contain the awesomness of a real three dimensional helmet. But it's still a good attempt to look like one of the 300 spartan soldiers.
ARTISTIC : This 3D print got my immediate attention since NASA had successfully landed a high-tech mars rover which weighed almost 2000 pounds. Scientists are now able to study the enviroment surrounding the rover so that the future generations will be able to land safely on the red planet. I haven't seen any Mars Curiosity Rover toys around, so printing these stl files make you one of the very few people that own a mini Curiosity.
WEIRD : One of the few things I can remember about my childhood is my lego set. To make this print complete, you will have to remove the head of a legoman that you own. I would have never though about designing such a ring so that would be reason why I named it a weird design.
USEFULL : I live in a dorm enviroment and the water faucets require the students to lean forward a little bit to wash face or brush teeth. Leaning for over a small period of time causes some discomfort and using this little foutain would greatly reduce the leaning distance which in return would provide a more easier water tap usage. If students are allowed to print something they need, in the near future, this little design would be my choice.
