Valentia
Revision as of 09:17, 5 May 2017 by Dasaki (talk | contribs)
Valentia Documentation
Valentia
Valentia is a Case-Rap variant by David Sanz Kirbis
open with spool
Valentia is a design by David Sanz Kirbis (aka. Dasaki) based in jlguisl's foldable [Case-Rap]. The name "Valentia" is taken from the name (Valentia Edetanorum) the original roman founders gave, in 138 BC, to the city in Spain where I'm living now: Valencia. Current stable pre-release is v0.3.
Specifications
  v0.3
Plastic Parts (exc. Extruder) todo
Non Printed Parts (approx.) todo
Cost (USD) todo
Controller Electronics todo
Printing Size (mm) 200 x 200 x 160
Motors 4 x NEMA 14, 1 x NEMA 17 Stepper
Frame Material 10mm Plywood
Frame Manufacture Basic Woodwork Tools
Size (WxLxH) Open:40x50x44cm Closed: 40x10x48cm
Weight 5Kg
Introduction
jlguils' design was released under GNU / GPL license (as it is based in the design of the Mendel90, also GNU / GLP ), so I'm publishing my own variant under the same GNU GENERAL PUBLIC LICENSE Version 3.
From the original design only the general division / parts of the wooden structure is kept, but all measures changed and parts are custom designs to suit two of the goals: low volume and low weight.
Documentation of current stable versión v0.3 is ongoing, but sources (Sketchup Make file and configured Marlin firmware) are pre-released on the project's github.
Here you got some pictures:
open without spool front view left view right view top view back view handle/spool holder detail
