GUS Simpson Buyers Guide
From RepRapWiki
GUS Simpson Documentation
Main page | GUS Simpson Buyer's Guide | GUS Simpson Build Manual | GUS Simpson User Manual | GUS Simpson improvements | GUS Simpson electronics and calibration
Printed Parts
It is recommended to print these parts in PLA at a 0.3mm layer height, 3 perimeters, 25% infill, and three top and bottom solid layers. It is also recommended to print HUB BOTTOM.stl, BOWDEN NUT.stl, and LOCK NUT.stl at a 0.2mm layer height due to the threads contained in these parts. HUB BOTTOM.stl should be printed with at least 50% infill as this part holds the whole assembly together in the center. Using these settings, it should take roughly 750-800 grams of PLA and depending on your slicing settings anywhere from 40-45 hrs to print.
Quantity Part Name Comment Photo
3
Shoulder
This part is the bottom of GUS's arms, also used as extruder mount and for holding base plates together
3
Motor arm
This part is the hardest one to print, and it serves as motor holder as well as the manipulator part
3
Slave arm
This part is used as a third part of manipulator, and connects to the Hub.
3
Pulley
It is better to make steel pulley if you can
1
Hub bottom
The bottom of the hub with hotend mount, partially compatible with Kossel
1
Hub center
The center of the hub
1
Hub top
The top of the hub
1
Hub washer
Washer to be inserted between hub center and hub top
1
Hub screw
Structural element for the hub - it holds the hub together. Also it has a nut slot for a bowden tube
1
Lock nut
A nut to hold the hub together
1
Bowden nut
A nut to hold the filament bowden tube's nut on the hub screw
3
Eccentric stop
Plastic endstop pusher
3
Plastic washer
A washers for the shoulder holding screws on plates - makes the whole thing more pretty
Waterjet parts
1
Bottom plate
Bottom plate of the GUS
100px
1
Top plate
Top plate of the GUS, have a space for the heater
100px
1
Basalt bed
Basalt bed to print on. Also can be aluminum or glass
100px
Vitamins
1
Teflon (PTFE) bowden tube
4mm OD x 2mm ID x 24 inches
19
608 Bearing
Better to be rubber-sealed
12
M8 washer
3
M8x100 Hex bolt
3
Tuning Peg
Machine Head Guitar Tuners
3
M3x16 bolt
9
M2x16 bolt
12
M8x60 Hex bolt
MUST be partially-threaded, DIN931
6
M8x55 Hex bolt
12
M3x6 bolt
6
M3x8 bolt
6
M3x20 bolt
2
M3x25 bolt
2
M3x30 bolt
2
M3x35 bolt
4
6702 bearing
2
M4 full nut
1
MK drive gear
3
Stretch spring
Original used this one
33
M8 Nylock stop nut
11
M3 Nylock stop nut
1
String
80lb+ tested braided fishing line
Electronics
4
Nema 17 stepper
4.5kg*cm
3
Micro limit switch
611-ZMA00A080L04PC or similar
1
3D printer controller
Could be RAMPS 1.4
1
Power supply
24v recommended if the controller supports it
1
Round heated bed
Circular 24V silicone rubber heater bed 200mm diameter (8")
1
Hot end
anUBIS recommended
Links
1. Original BOM on github
