Mechanical testing of polymer components made with the RepRap 3-D printer
Sunhusky.png By Michigan Tech's Open Sustainability Technology Lab.
Wanted: Students to make a distributed future with solar-powered open-source RepRap 3-D printing and recyclebot recycling.
Contact Dr. Joshua Pearce or Apply here
MOST on RepRap: Projects and Publications], Methods, Lit. reviews
Twitter updates @ProfPearce
This page is part of an international project hosted by MOST to use RepRap 3-D printing to make OSAT for sustainable development. Learn more.
Research: Open source 3-D printing of OSAT RecycleBot LCA of home recyclingGreen Distributed Recycling Ethical Filament LCA of distributed manufacturingRepRap LCA Energy and CO2 Solar-powered RepRapssolar powered recyclebot Feasibility hub Mechanical testing Lessons learnedMOST RepRap Build
Make me: Want to build a MOST RepRap? - Start here! • Delta Build Overview:MOSTAthena Build OverviewMOST metal 3-D printer Humanitarian Crisis Response 3-D Printer
Overview
The purpose of this project is to determine mechanical properties of polymer components printed with the open source RepRap Mendel 3-D printer. Standard test methods are to be used to gather accurate and acceptable test data. The results of the mechanical testing will be used for engineering analysis of parts designed to be created with the RepRap.
The results are published here: B.M. Tymrak, M. Kreiger, J. M. Pearce, Mechanical properties of components fabricated with open-source 3-D printers under realistic environmental conditions, Materials & Design, 58, pp. 242-246 (2014). http://dx.doi.org/10.1016/j.matdes.2014.02.038. open access
Detailed coverage here:
Testing Standards
ASTM D638-10 Standard Test Method for Tensile Properties of Plastics
Test Specimen
ASTM Type I specimen - STL file revised with starting point outside of specimen STL file
Printer settings to test
All g-code will be generated using Slic3r software from http://slic3r.org/
Slic3r Setting
Layer Height 0.4mm, 0.3mm, 0.2mm
Fill Density 1.0
Fill Angle 0, 45
Fill Pattern Rectilinear
Solid Fill Pattern Rectilinear
Test Equipment
  • MTS Test System in M&M 413
  • MTS Testworks Software on test machine computer
  • Epsilon Technology 3542-0200-050-ST Extensometer
Specimen to Test
Naming Protocol
Layer Height-Orientation-Fill-Print#-Source
ie. (3-90-100-1 MTU) for 0.3 LH, 90 deg Fill Orientation, 100% Fill, Print #1, at MTU
Base Testing
  • 3 layer heights - .2, .3, .4; orientations 45, 90; 12 testing conditions; 10X each; 120 total tests.....
PLA
  • 0.4mm 90 deg (10 printed) 45 deg (10 printed)
  • 0.3mm 90 deg (10 printed) 45 deg (10 printed)
  • 0.2mm 90 deg (10 printed) 45 deg (10 printed)
ABS
  • 0.4mm 90 deg (10 printed) 45 deg (0 printed)
  • 0.3mm 90 deg (0 printed) 45 deg (0 printed)
  • 0.2mm 90 deg (0 printed) 45 deg (0 printed)
See Also
