Parallel extruder
From RepRapWiki
very, very basic ideas so far here. Many people are talking of tool switching, which if i understand correctly would be removing an extruder (gears and all) from the machine and placing a new one, or at least rotating out the tools. Therefore i doubt that i understand it because that would be horrendously wasteful.
my idea is to have one solid metal piece (would need machining, but it couldn't be too difficult) with 6 nozzles cut into it,
which is kept at the lowest melting point of the various plastics being used. IE if your using PLA and ABS, it stays at 150 for the PLA. only ABS, heat it up to ABS's melting point. these 6 nozzles are arranged at the corners of a parallelogram with angles 60 and 120, then the final two are at the midpoints of the 2 longer sides.
attached to that (somehow, fuzzy on this part) are 6 short lengths of copper pipe wrapped in nichrome. each of these is heated to whatever temperature the material going through it requires. The area in between should probably be filled with some form of insulation so they don't heat eachother.
the distance between the actual nozzles on the aforementioned piece should be equal to one step (IE, one bead of melted plastic) so that if you DON'T need multiple materials, you can run say ABS through all 6, and print with 6x speed, since your moving 3 steps then dropping 6 beads, rather than move one drop one move one drop one.
Now the rest i haven't even sketched in Inventor yet, but basically place the extruder parallelogram next to the gear, with the stepper motor on the opposite side, then have each nozzle function as a bowden extruder.
excuse me for being incoherent,i've put off assembling my reprap until christmas break so it doesn't cut into schoolwork, so i have an academic understanding of all this, not a functional one.
