Rostock-Montpellier
Rostock-Montpellier
Release status: experimental
Description | Rostock-Montpellier is a portable delta robot 3D printer.
License | |
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | ?
External Link | ?
The Rostock-Montpellier is a delta 3D printer based on the Rostock mini.
It is focused to print as fast as possible and sustain it for a couple of hour.
Design goals
Target setting to print a bunch of parts quickly.
- Acceleration : 10G
- Speed, Travel : over 1000mm/s
- Volume : Ø170x170
Actual settings
- Accleration, XY : 4G (39224mm/s²)
- Accleration, Z : 1G (9806mm/²)
- Speed, travel : 800 mm/s
Performed settings
Setting used with the latest prototype during "Les 24h de l'imprimante 3D" show at Montpellier in June.
- Accleration, XY : 2G (19613mm/s²)
- Speed, travel : 700 mm/s
- Speed, infill : 160mm/s
- Speed, perimeter : 120mm/s
- Speed, external perimeter : 70mm/s
- Layer : 120µm
- Volume : Ø170x127mm
Prototype design
To accelerate the Rostock and get high speed without replacing motors by expensive one, according the Newton's 2nd Law there is 2 things to do :
- The parts in movement have to be lighten. If the mass is divided by two, the acceleration can be multiplied by 2.
- The frictions have to be reduced, less force to move, more accleration.
The platform and the carriage has been redesigned in a way that an existing Rostock can be updated with the Rostock-Montpellier parts.
