Screwball-Bot
From RepRapWiki
These are good resources for creating wiki pages.
Very Messy Example and Columbus
--Sebastien Bailard 07:23, 10 September 2010 (UTC)
Example Development
Release status: unknown
Description documenting a generic tool/artpiece
License GPL
Author RichRap
Based-on Sui Generis
Categories T-Slot, Files Missing, Needs Parts List, Needs Build Instructions
CAD Models none
External Link none
Files (Coming Soon!!!)
Your-File-Name SOLID MODEL ASSEMBLY These are CAD files for the Solid Model Assembly .xml.zip, .stl.zip --Example User 12:00, Today's Date 20xx (UTC)
Your-File-Name CAD FILES FOR PARTS These are CAD files for each part. .xml.zip, .stl.zip --Example User 12:00, Today's Date 20xx (UTC)
Your-File-Name EVEN MORE FILES These are are even more files. .xml.zip, .stl.zip --Example User 12:00, Today's Date 20xx (UTC)|-
Your-File-Name SOLID MODEL ASSEMBLY This is the final finished machine N/A --Example User 12:00, Tomorrow's Date, 20xx (UTC)
Please edit this and click the links to put in your own files! --Sebastien Bailard 08:34, 10 September 2010 (UTC)
My chunky T-Slot Bot with Ballscrews called Screwball-Bot.
It's designed to use as many off the shelf components as possible and any parts that need to be made are possible with simple tools and are mainly non-critical to the end quality or ability of the machine.
It's not as expensive as it may look to do this so don't discount it out of your budget until you have read more below -
The 'working' Screwball-Bot - May 2011 (It will never be defined as 'completed')
I need to work out how to add images to this page, hopefully this will show the columbus image below?
COL-TEST-104 Front View, some components removed for clarity.
Introduction
After my first Repstrap (not documented sadly) in the summer of 2010 I decided to make a new machine based on T-Slot MCS Aluminium Extrusion – http://4.bp.blogspot.com/_yfTUA-zOIkk/TSSkkR3BdYI/AAAAAAAAAHA/aIeTHqk7BBI/s320/30_30_MCS.jpg
Project goals
The original design aims for Screwball-Bot were defined in Jan2011, being 20 goals -
  1. Faster print speed - (This is my main driving factor after having a slow Repstrap for 6 months)
  2. Change to Ballscrews on X and Y Axis (not sure about Z at the moment)
  3. Revised Electronics (Mega based - and RAMPS based)
  4. Integral Electronics Tray and wiring with reliable connectors.
  5. Change from a fixed to Moving Y bed and print platform.
  6. Remove the Gantry head arrangement for the Z axis - Need to think of a simple way to do this...
  7. Simplify the Z axis by using dual Nema 17 motors (I may regret that decision...).
  8. Increase build-area to 300mm x 450mm x 300mm (Y being easily changed from 100mm upwards)
  9. Have easy-fit/remove build platform at different sizes and thickness
  10. Vertical mount Extruders
  11. Dual Extruder ends with remote mounts for Bowden mounted extruders
  12. Switch to Herringbone Extruder Gears
  13. Filament coil store and supply feed for 2 reels built into the machine
  14. Heated bed
  15. Resistor block Hot-ends
  16. Multiple Thermistors / readings
  17. Use as many off-the-shelf components as possible
  18. Use the off-the-shelf parts to maintain quality and accuracy in the design
  19. Do the minimum amount of machining as possible
  20. Where I need to do machining then it needs to be non-critical or easily adjusted to retain quality
I also want the ability to add Paste extruders and all sorts of other things, so the mounting and exchange should be as easy as possible with minimum (no) re-calibration required.
And 1.75mm Filament was getting more available and clearly making a difference, so using that was another project goal.
Bill of Materials/Parts List
Parts used – ready made / off the shelf
  1. MCS Aluminium Extrusion -
  2. part
  3. part
Parts home-made - for the machine build
  1. part
  2. part
  3. part
Parts used – ready made / off the shelf Parts used – ready made / off the shelf
Mechanical Assembly
Electronics
(Remember to add links to RAMPS, steppers and the MEGA) Design Manufacture Assembly Testing
Initial tool-chain software and firmware
Problems encountered with Screwball-Bot
Time taken
Costs
Performance, quality and calibration
What I would do different next time (yes, there will be another one)
More Examples
