Snappy Buyers Guide
From RepRapWiki
The links and information below may fall out of date. The most up-to-date information can be found at the project's GitHub site:
Required Tools
You will need the following tools to assemble this printer.
Qty Description
1 Multimeter for checking wiring.
1 Soldering iron.
1 Small rubber mallet to help convince some parts to join.
1 Mineral oil for lubrication.
1 Fine grit sandpaper to clean up the rails.
1 Optional cyanoacrylate glue. (super-glue)
Electronics
You'll need controller electronics to drive the Snappy. Here's what I recommend. Prices given are based on what I found on Amazon with a cursory search. All parts found had free shipping options. All costs are in US Dollars.
Qty Description Total Cost (US$) Where Found
1 Power Supply, 120W. (300W w/ Heated Bed) 20 Amazon.com
1 Controller electronics. (RAMPS1.4+2560+Pololus) 45 Amazon.com
3 Mechanical microswitch end-stops and wiring. 5 Amazon.com
5 NEMA17 Stepper Motors, 40mm length, 1m cable 65 Amazon.com
1 J-Head Extruder hot end w/heater, thermistor. 32 Amazon.com
2 40mm 12v 2-pin cooling fan, 10mm thick. 4 Amazon.com
1m Wire, dual conductor, 22 gauge, stranded 1 Amazon.com
1 Heated Build Platform. (optional) 9 Amazon.com
Hardware
You'll need the following Hardware to build the cartesian frame:
2.4Kg Plastic Filament. (@ $30/Kg) 72 MatterHackers.com
2 ACME threaded rod, 3/8"-8 x 12" 18 McMaster.com
1 Extruder Drive Gear 4 Amazon.com
1 686 bearing. 1 Amazon.com
1 Borosilicate glass build platform. (213x200mm) 22 Amazon.com
4 Mini binder clips. 3 Amazon.com
Total Cost
Not counting shipping costs, time, and labor.
  • ~$292 without Heated Bed.
  • ~$310 with Heated Bed.
Printed Parts
All parts should be printable inside a 150mm x 135mm x 110mm build volume. The sled end-cap part, which is longer than 150mm, can be printed diagonally.
Recommended slicer settings:
  • 3 perimeters layers
  • 3 top and bottom layers
  • 0.3 or smaller layer height
  • 20% or better infill
  • grid/rectangular infill
  • No support necessary
  • No Raft or brim necessary
You will need to print out the following parts:
Qty Name Download
1 Slop Calibrator download
2 Rail X-Y Motor Segment download
1 Drive Gears download
4 Motor Mount Plates download
10 Rail Segment download
4 X-Y Slider Sled download
2 X-Y Joiner download
2 Sled Endcap download
1 Platform Supports download
2 Rail Y Endcap download
2 Y-Z Bottom Joiner download
4 Support Legs download
2 Rail Z Motor Segment download
2 Lifter Rod Coupler download
2 Lifter Lock Nut download
2 Z Slider Sled download
1 J-Head Extruder Platform download
1 Extruder Motor Clip download
1 Extruder Idler & Latch download
1 Extruder Fan Shroud download
1 Extruder Fan Clip download
1 Cooling Fan Shroud download
1 Rail Z Endcap download
1 Spool Holder download
2 Cable Chain Links download
1 Cable-Chain Mounts download
And one of the following motherboard mounts, depending on which electronics you use:
Qty Description Download
1 RAMPS MotherBoard Mount download
1 RAMBo MotherBoard Mount download
So, overall, about 160+ hours of printing.
