Pronterface + Sprinter extruder ex temp rising rapidly
Posted by michaelc
October 10, 2011 09:07AM
Hello,
my extruder heating resistor temp is rising very fast despite having a skeinforge heating rate of 0.1 Celcius/second. This means it's over heating and fluctuating wildly. Can anyone advise me how to slow it down?
Ponterface/Sprinter + Sanguinololu
thanks,
Mike
Re: Pronterface + Sprinter extruder ex temp rising rapidly
October 10, 2011 09:29AM
Did this just start happening when you switched to sprinter? Make sure you have the right thermistor selected in your firmware.
Also I'm pretty sure the skeinforge setting for heating rate in only affects how long it will orbit, waiting for the temp to increase. It doesn't actually control the amount of time it takes to heat up. The idea is if you time how long the heating takes and put the number in there to get an accurate wait time for the temperature change.
October 10, 2011 01:14PM
The thermistor table is correct and selected.
I had no problems with previous firmware on Gen6, same set up.
Is there a way to limit the power to the heating resistor from within the firmware?
Mike
