Re: Whats special about the goal of 'reprap' vs existing capabilities/realities like CNC milling machines November 04, 2011 05:41PM |
Re: Whats special about the goal of 'reprap' vs existing capabilities/realities like CNC milling machines November 04, 2011 05:52PM |
Re: Whats special about the goal of 'reprap' vs existing capabilities/realities like CNC milling machines November 04, 2011 06:08PM |
Re: Whats special about the goal of 'reprap' vs existing capabilities/realities like CNC milling machines November 04, 2011 06:15PM |
Re: Whats special about the goal of 'reprap' vs existing capabilities/realities like CNC milling machines November 04, 2011 06:33PM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Whats special about the goal of 'reprap' vs existing capabilities/realities like CNC milling machines November 04, 2011 06:35PM |
Re: Whats special about the goal of 'reprap' vs existing capabilities/realities like CNC milling machines November 04, 2011 06:51PM |
Re: Whats special about the goal of 'reprap' vs existing capabilities/realities like CNC milling machines November 04, 2011 07:02PM |
Re: Whats special about the goal of 'reprap' vs existing capabilities/realities like CNC milling machines November 04, 2011 07:22PM |
Re: Whats special about the goal of 'reprap' vs existing capabilities/realities like CNC milling machines November 04, 2011 07:32PM |
Re: Whats special about the goal of 'reprap' vs existing capabilities/realities like CNC milling machines November 04, 2011 07:40PM |
Most modern and high quality CNC machining centers have full enclosures.
But then again, I can imagine a caveman making an axe (composed of say wood, a chiselled rock and some roots to tie the rock to the wood) to make another axe
Yet, all I have been saying is Reprap is not special and novel.
Re: Whats special about the goal of 'reprap' vs existing capabilities/realities like CNC milling machines November 04, 2011 07:48PM |
nov·el 2 (nvl)
adj.
Strikingly new, unusual, or different.
FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Whats special about the goal of 'reprap' vs existing capabilities/realities like CNC milling machines November 04, 2011 08:01PM |
Re: Whats special about the goal of 'reprap' vs existing capabilities/realities like CNC milling machines November 04, 2011 10:30PM |
Re: Whats special about the goal of 'reprap' vs existing capabilities/realities like CNC milling machines November 04, 2011 11:59PM |
Re: Whats special about the goal of 'reprap' vs existing capabilities/realities like CNC milling machines November 05, 2011 12:12AM |
Re: Whats special about the goal of 'reprap' vs existing capabilities/realities like CNC milling machines November 05, 2011 01:11AM |
Re: Whats special about the goal of 'reprap' vs existing capabilities/realities like CNC milling machines November 05, 2011 04:55AM |
Re: Whats special about the goal of 'reprap' vs existing capabilities/realities like CNC milling machines November 05, 2011 05:44AM |
Depends on one's budget.
If you are talking about ultra high precision CNC milling centers with all the bells and whistles, of course those are expensive. For a cheapo mill that you conver to CNC, it can be had for roughly ~$600 new. Less used.
Most modern and high quality CNC machining centers have full enclosures. Your workspace can be very clean and quiet. In fact many design studios of large companies have CNC milling machines in or near design studios, often next to some 3D printer also.
The point of my example of the cavemen was to counter your suggestion that except for CNC (mills/lathes/FDM) you cant make tools using old tools.
I stated that cavemen axe make-belief as only a sample scenario where that is actually true that you can make new tools with old tools. Plus, it doesnt need to be direct via 1 tool to the same type of tool. It can be via the generation of intermediate tools that can finally replicate the original tool. How else do you think humanity has reached its level of technological advancement if not for the fact this was true? The fact that old and existing tools are consistently used to generate the next generation of tools.
Regarding open source CNC milling? I know of so many cases.
Re: Whats special about the goal of 'reprap' vs existing capabilities/realities like CNC milling machines November 05, 2011 10:29AM |
Re: Whats special about the goal of 'reprap' vs existing capabilities/realities like CNC milling machines November 07, 2011 05:47AM |
Re: Whats special about the goal of 'reprap' vs existing capabilities/realities like CNC milling machines November 07, 2011 05:51AM |
takes a better machine to make a lesser one, always, no exceptions
Re: Whats special about the goal of 'reprap' vs existing capabilities/realities like CNC milling machines November 07, 2011 06:05AM |
Re: Whats special about the goal of 'reprap' vs existing capabilities/realities like CNC milling machines November 07, 2011 06:39AM |
Terry Pratchett, The Truth
The only tools a dwarf needed were his ax and some means of making fire. That'd eventually get him a forge, and with that he could make simple tools, and with those he could make complex tools, and with complex tools a dwarf could more or less make anything.
Re: Whats special about the goal of 'reprap' vs existing capabilities/realities like CNC milling machines November 07, 2011 05:22PM |
nophead
Of course, so to get mass take-up by people it has to be cheap as most people don't have the budget and space to have a machining centre at home.
No it was you that introduced expensive machining centres:
Your cheapo $600 mill is not going to be clean and quiet.
No my argument is they can't make themselves. Reprap is the first SELF replicating 3D printer. In that respect it is novel. Of course, given a selection of tools, a craftsman can make other tools. They can even make 3D printers. The novel bit about reprap is it makes the parts that would normally require a craftsman.
We are talking about SELF replication, not general fabrication, or old tools being used to make better new tools.
Yes but they aren't 3D printers, don't have the same mass appeal, and therefore don't get the same media hype.
You are arguing that Reprap is not unique, but it clearly is. It is the first affordable 3D printer and has sparked a revolution of people using 3D printers at home, whether you like it or not.
Re: Whats special about the goal of 'reprap' vs existing capabilities/realities like CNC milling machines November 07, 2011 05:45PM |
You will notice I always use the term "CNC mill/lathe", since I was being generic. There are so many varieties nowadays its hard to draw a real definition, but there are machines that combine both milling and turning capabilities in one machine so it will be able to do both. For example, the so called "swiss" CNC machines often have multiple spindles for work holding and/or cutting. Alternatively, just get a multi axis CNC milling machine and you can do almost everything. Hell, even a three axis CNC milling machine can be used as a lathe for turning. You hold the workpiece on the spindle and use the stage for tool holding, and you essentially get a lathe. This is commonly done in the industry and in home shops. A milling machine with sufficient work envelope has no problem replicating parts for itself when used intelligently.Quote
Noobman
NoobMan Wrote:
> @ TTYlater:
> I see you have extensive knowledge of the CNC
> area. Can you please enlighten me on a few
> aspects:
> 1) CNC lathe self-replicating: how do you make its
> own jaw-chuck body, since ... for a start, you can
> never catch a brut material big enough in it ...
> or eventually you could pre-machine the brut on
> another machine but that means the first lathe
> cant do itself;
> 2) CNC mill self-replicating: how does a mill make
> its own table ... because that table is *always*
> actually bigger than its own working area?
> 3) Why, in order to make a mill or lathe,
> proffesionals do actually need like 10-12
> different specialized machines to make their
> parts; and why each of these machines must have
> much better precisions than the final product will
> have; sort of it takes a better machine to make a
> lesser one, always, no exceptions - didnt
> machinists heard of replication?
> And finally something really tricky. When a young
> mind is so stubborn that does not want to listen /
> learn / understand other points of view - who's
> *loss* is that? And also about trying to convince
> all others of a certain belief - what can be ever
> *gained* from that?
> Cheers.
Re: Whats special about the goal of 'reprap' vs existing capabilities/realities like CNC milling machines November 07, 2011 06:27PM |
http://reprap.org/wiki/RepRapWiki:About under "Realization"
a much cheaper machine with the novel capability of being able to self-copy (material costs are about €350)
Re: Whats special about the goal of 'reprap' vs existing capabilities/realities like CNC milling machines November 07, 2011 06:50PM |
Re: Whats special about the goal of 'reprap' vs existing capabilities/realities like CNC milling machines November 07, 2011 07:54PM |
Re: Whats special about the goal of 'reprap' vs existing capabilities/realities like CNC milling machines November 07, 2011 07:57PM |
