Re: Whats special about the goal of 'reprap' vs existing capabilities/realities like CNC milling machines November 07, 2011 07:57PM |
Re: Whats special about the goal of 'reprap' vs existing capabilities/realities like CNC milling machines November 07, 2011 10:15PM |
Re: Whats special about the goal of 'reprap' vs existing capabilities/realities like CNC milling machines November 07, 2011 10:29PM |
Re: Whats special about the goal of 'reprap' vs existing capabilities/realities like CNC milling machines November 07, 2011 10:47PM |
Re: Whats special about the goal of 'reprap' vs existing capabilities/realities like CNC milling machines November 07, 2011 11:06PM |
Re: Whats special about the goal of 'reprap' vs existing capabilities/realities like CNC milling machines November 08, 2011 04:05PM |
nophead
No I am arguing that reprap machines are more popular than CNC routers because you can put one in a normal domestic setting due to being small, quiet, clean and cheap.
nophead
Irrelevant statement. What has the size of a Z corp machine got to do with reprap?
nophead
Yes I have one. Much louder than my Pursa, which is almost silent. Just the spindle running with no load is louder.
nophead
Yes you keep taking about machines with full enclosures. Not something you can buy for the price of a reprap.
nophead
Maybe true for Makerbots with no microstepping, but not true for the current generation of Reprap, which is Prusa with 16th step drivers and it is almost silent, quieter than a laser printer.
True, but what has that got to do with Reprap?
Here you go mixing up cheap CNC mills and expensive ones again. If you get a CNC mill for a similar price to a reprap it will have a noisy spindle and no enclosure. If you get a nice quiet one with a full enclosure you are in a another price bracket.
nophead
Again you are dead wrong. A CNC lathe cannot make much of itself. Most mills and routers cannot either. Yes CNC machines are used to make other CNC machines, but not copies of themselves. For example a major part of a lathe is the bed. Not something you can pick up in a hardware store. Also not something you make with a lathe. The spindle of a mill is not something you make with a mill, you need a lathe.
nophead
Reprap is a replicator in the sense that it makes all the parts that you cannot buy cheaply off the shelf and would otherwise require another machine or some human labour and skill to make. The fact it doesn't make nuts and bolts and stepper motors means it technically falls way short of self replication, but practically it doesn't matter because you can buy such things cheaper and better than you can make them.
nophead
No if you read any definition of self replication it does not require intelligence. Take bacteria and viruses as prolific examples.
nophead
Yes it is a tool for humans to use. That is why people want them.
Yes but that makes a massive difference. You tell the machine to start and then leave it to get on with it while you do something else. Manual tools need time, effort, and in a lot of cases skill. They are also expensive and take up a lot of room because you need a small workshop to be able to hand make the variety of things you can print with a 3D printer. Very few people have enough tools to make things, they just buy them.
Whether you like it or not repraps are popular and they replicate, proof is tens of thousands of people now poses them, and they have caught the attention of the media. In that respect they are different from everything that has gone before. Get over it. If you prefer CNC routers and lathes go troll cnczone.com.
Re: Whats special about the goal of 'reprap' vs existing capabilities/realities like CNC milling machines November 08, 2011 04:35PM |
julianh72 Wrote:
> @TTYlater:
> Do you accept that a virus is self-replicating?
> Because if you do, than RepRap is
> self-replicating; if not, then we are never going
> to meet on common ground.
> Characteristics of a virus:
> A virus is a small infectious agent that can
> replicate only inside the living cells of
> organisms. ... About 5,000 viruses have been
> described in detail, although there are millions
> of different types. ... Viruses are found in
> almost every ecosystem on Earth and are the most
> abundant type of biological entity. ... Some
> viruses including those causing AIDS and viral
> hepatitis evade these immune responses and result
> in chronic infections. Antibiotics have no effect
> on viruses, but several antiviral drugs have been
> developed. ... Viruses are an important natural
> means of transferring genes between different
> species, which increases genetic diversity and
> drives evolution.
> A virus is incapable of existing and
> self-reproducing alone "in the wild" - it survives
> and reproduces by subverting the chemistry and
> biology of the cells of the host organism for its
> own reproduction. It doesn't even carry all of the
> chemical "raw material" that it needs to reproduce
> - it gets almost all of the "stuff" it needs to
> reproduce from the host. It may be injurious (or
> even fatal) to the host - it doesn't care, as long
> as enough new viruses are produced before the host
> dies, and as long as new hosts can be found, then
> the virus will propagate. Some viruses survive and
> propagate though a symbiotic relationship with the
> host; for example, converting waste products into
> useful constituent chemicals. In essence, it is
> the DNA of the virus that self-replicates (albeit
> with mutations) - the virus "package" and the host
> are just the vectors used to reproduce the DNA of
> the virus.
> RepRap has "gone viral" in every sense of the
> word:
> Characteristics of a RepRap:
> A RepRap is a small infectious machine that can
> replicate only inside the mind of hosts. ... About
> 50 RepRaps have been described in detail, although
> there are thousands of different types. ...
> RepRaps are found in almost every ecosystem on
> Earth and are the most abundant type of domestic
> 3D printer. ... Some RepRaps result in chronic
> infections. Wives / Husbands / Significant Others
> have no effect on RepRaps, and no anti-RepRap
> drugs have been developed. ... RepRaps are an
> important means of transferring design ideas
> between different species of RepRap, which
> increases genetic diversity and drives evolution.
> A RepRap is incapable of existing and
> and reproduces by subverting the mind and wallet
> of the host organism for its own reproduction. It
> doesn't even carry all of the physical "raw
> material" that it needs to reproduce - it gets the
> "vitamins" it needs to reproduce from the host
> (and the local hardware shop). It may be injurious
> (or even fatal) to the host - it doesn't care, as
> long as enough new RepRaps are produced before the
> host dies (or loses interest), and as long as new
> hosts can be found, then RepRap will propagate.
> Some RepRaps survive and propagate though a
> symbiotic relationship with the host; for example,
> converting plastic filament into useful objects.
> In essence, it is the DNA of the RepRap that
> self-replicates (albeit with mutations) - the
> RepRap "machine" and the host are just the vectors
> used to reproduce the DNA of RepRap.
This seems to be a common problem. People are unclear about the facts. Even wtihin this thread, at least some have now conceded that old tools can make similar or newer better tools. This has been the reality of our existence and the reason behind our human technological progress. So your points here are completely false. Historically CNC mills/lathes can and do make parts for itself. Not being aware of this, does not make it untrue. From that perspective, reprap is not special in this front, since it is also just another line of tools used by the operator to perform tasks of manufacturing. The only difference is its 'consumer grade'.Quote
> Stone hammers don't exist for the purpose of
> making more stone hammers; lathes don't exist to
> make other lathes; CNC Mills don't exist to make
> other CNC Mills; the vast majority of tools are
> invented in order to make other things. But herein
> lies the distinction - it is of the very essence
> of RepRap that a prime purpose of its existence is
> to self-reproduce - as well as to make "useful
> stuff" for the host.
Re: Whats special about the goal of 'reprap' vs existing capabilities/realities like CNC milling machines November 08, 2011 04:45PM |
kyleeamonahern Wrote: ------------------------------------------------------- > lol!! maybe this dude is working for some company, > and the open source 3d printer threatens its > monopoly, so he is either trying to waist our time > or change our minds about the reprap so we spend > our resources on something else. At this point I > dont understand why else he would be keeping this > up! lolThis is ignorance talking. Are you the same type that believe defense attornies are the enemies because they defend the accused and serve their important and required role as an adversary in our rule of law? Are you the type that hates attorneys that defend casey anthony or oj simpson?
Re: Whats special about the goal of 'reprap' vs existing capabilities/realities like CNC milling machines November 08, 2011 08:14PM |
Admin Registered: 19 years ago Posts: 7,883 |
Re: Whats special about the goal of 'reprap' vs existing capabilities/realities like CNC milling machines November 08, 2011 09:37PM |
Re: Whats special about the goal of 'reprap' vs existing capabilities/realities like CNC milling machines November 09, 2011 02:26AM |
Re: Whats special about the goal of 'reprap' vs existing capabilities/realities like CNC milling machines November 09, 2011 02:38AM |
Re: Whats special about the goal of 'reprap' vs existing capabilities/realities like CNC milling machines November 09, 2011 03:02AM |
TTYlater
Re: Whats special about the goal of 'reprap' vs existing capabilities/realities like CNC milling machines November 10, 2011 11:22PM |
Re: Whats special about the goal of 'reprap' vs existing capabilities/realities like CNC milling machines November 11, 2011 04:36AM |
Re: Whats special about the goal of 'reprap' vs existing capabilities/realities like CNC milling machines November 11, 2011 06:58AM |
Re: Whats special about the goal of 'reprap' vs existing capabilities/realities like CNC milling machines November 11, 2011 09:25AM |
Saying that I used a mdf cnc machine to build the sumpod prototype.
Re: Whats special about the goal of 'reprap' vs existing capabilities/realities like CNC milling machines November 11, 2011 11:46AM |
Re: Whats special about the goal of 'reprap' vs existing capabilities/realities like CNC milling machines November 11, 2011 02:42PM |
Re: Whats special about the goal of 'reprap' vs existing capabilities/realities like CNC milling machines November 11, 2011 04:27PM |
Re: Whats special about the goal of 'reprap' vs existing capabilities/realities like CNC milling machines November 11, 2011 06:37PM |
Re: Whats special about the goal of 'reprap' vs existing capabilities/realities like CNC milling machines November 12, 2011 08:07AM |
Re: Whats special about the goal of 'reprap' vs existing capabilities/realities like CNC milling machines November 12, 2011 05:07PM |
Re: Whats special about the goal of 'reprap' vs existing capabilities/realities like CNC milling machines November 12, 2011 05:52PM |
Re: Whats special about the goal of 'reprap' vs existing capabilities/realities like CNC milling machines November 23, 2011 04:27PM |
Re: Whats special about the goal of 'reprap' vs existing capabilities/realities like CNC milling machines November 23, 2011 05:39PM |
Re: Whats special about the goal of 'reprap' vs existing capabilities/realities like CNC milling machines November 23, 2011 06:17PM |
If someone argues reprap is different than a dremel in terms of their ability to be used for self replication, it demonstrates misunderstanding.
Drop the 'replication' part
Re: Whats special about the goal of 'reprap' vs existing capabilities/realities like CNC milling machines November 23, 2011 07:09PM |
