Z alignment better on smaller layers…?
November 13, 2011 06:13PM
I've gotten to the point where my layer alignment is excellent on small objects and small layers of large objects, but strangely enough it gets pretty bad on the larger layers. For example, I printed the Vanderbilt Mansion, and the top layers came out very nicely aligned:
But the layers on the bottom look pretty narsty:
Feels hardware-related. My belts are tight and my carriage has no side-to-side wobble or anything.
Prusa, Sanguinololu 1.3a, Sprinter, Replicatorg, Slic3r-generate gcode, 0.15 mm layers, 40 mm/sec perimeters.
Re: Z alignment better on smaller layers…?
November 13, 2011 06:22PM
November 13, 2011 06:33PM
Well darn, looks like you got me. After printing these bearing guides, it seems that my belts—especially the X-belt—are no longer totally level with the idler bearings. Poop.
November 13, 2011 06:35PM
If you use a tensioner like [www.thingiverse.com] you could try turning it over so the belts are higher.
EDIT: Ok I see you were the last person to comment on those tensioners so you obviously have them.
EDIT 2: I had the wrong link
Edited 2 time(s). Last edit at 11/13/2011 07:39PM by Sublime.
November 13, 2011 07:03PM
For my Y-carriage, I use the built-in tensioners in [www.thingiverse.com], so I'll probably print a spacer or two for it. The x-carriage is a tougher nut to crack since I can go taller but not shorter with the built-in tensioner. Maybe I'll try something with zipties.
November 13, 2011 07:24PM
Before:
After:
November 13, 2011 07:41PM
November 13, 2011 07:47PM
Testing now…
Edit: Alignment is flawless now. Thanks a ton!
Edited 2 time(s). Last edit at 11/13/2011 09:24PM by Pointedstick.
