Re: Large-scale 3d printer October 16, 2015 01:51AM |
Re: Large-scale 3d printer October 16, 2015 01:55AM |
Re: Large-scale 3d printer October 16, 2015 02:03PM |
Re: Large-scale 3d printer November 09, 2015 10:09PM |
Re: Large-scale 3d printer November 09, 2015 10:13PM |
Re: Large-scale 3d printer November 10, 2015 11:46AM |
Re: Large-scale 3d printer November 10, 2015 01:19PM |
Re: Large-scale 3d printer November 10, 2015 01:23PM |
Re: Large-scale 3d printer November 10, 2015 01:34PM |
Re: Large-scale 3d printer November 10, 2015 05:43PM |
Re: Large-scale 3d printer November 10, 2015 09:19PM |
Re: Large-scale 3d printer November 10, 2015 09:51PM |
Re: Large-scale 3d printer November 10, 2015 10:02PM |
Re: Large-scale 3d printer November 10, 2015 10:07PM |
Re: Large-scale 3d printer November 10, 2015 10:16PM |
Re: Large-scale 3d printer November 11, 2015 12:00PM |
Re: Large-scale 3d printer November 11, 2015 12:10PM |
Re: Large-scale 3d printer November 11, 2015 01:12PM |
val c.
I am considering enclosing the entire behemoth, but I am still studying this venue.
davew_tx
So I decided first to create a printer while developing a vacuum. broken logic. I need a car, so develop the engine first, but first I need to make a cnc mill to make parts, but I need a foundry to cast the engine block,
Re: Large-scale 3d printer November 11, 2015 02:47PM |
davew_tx
val,
nice work for sure. you have solid ideas and I'd say your next batch of challenges will come once you start slicing/hosting/printing and learning about how the machine reacts to heat, time, motion, etc.
As for the 4 screw z axis, I had a 2 screw axis (18" parker daedal linear stages, 5mm lead screws, impossible to backdrive) on my first machine and found that I fiddled with the screws trying to coordinate them. As the head moved around the bed I'd see a need to adjust the z height by like a layer or two, especially on the first layer where adhesion and first layer laydown is critical. I ended up removing one side and just cantilevering the bed and was much happier. with one side driving, I then only had to fiddle with the 3 leveling screws, which was also done often. I know you can't cantilever your bed, but a large single motor and belting around each screw could be a solution IF you encounter what I did. You might not.
If I understand what you're proposing correctly (marineboard-heater-cork-glass) for a bed stackup, I wouldn't approach it that way, but this is your journey and thank you for sharing and not getting all butt hurt about critiques. This record of your discussions will help others.
I put away all my 3d stuff for a year and was liberated and felt happy not being immersed and obsessed. I'm getting my head back into it and fear my addiction is returning.
I see a reference article stating the Objet1000 is $600k plus $40k for a material loading.
I found $675k given by someone who received a quote.
I saw an article stating $40k, but that can't be correct as the basic small Fortus is above that, and a Uprint Plus setup will run you $20k.
I'm in the ballpark at $700k.
Cheers and give your beast a good name!
I called mine Mitus, as in My Fortus.
I had a need for some large parts (vacuum cleaner development) and got the quotes for parts and was shocked.
Re: Large-scale 3d printer November 11, 2015 02:55PM |
Re: Large-scale 3d printer November 11, 2015 03:11PM |
JamesK
val c.
Looking at the photos, I think it's more or less the case that the room is the enclosure! I'm amazed and impressed by your ambition with this project, it makes my own attempts seem so very moderate.
davew_tx
That sounds oh so familiar. I have quite the list of half finished projects that are on hold while I make something else.
Re: Large-scale 3d printer November 11, 2015 03:16PM |
bonmotwang
Glad we are talking about big printer here, because I am building one too.
I brought up the topic of thermal expansion in my other thread, but nobody commented anything. LoL.
At 1 meter length, the expansion is about 1mm from 20C to 60C.
Do you think this will cause any issues in your design?
Re: Large-scale 3d printer November 11, 2015 03:38PM |
Re: Large-scale 3d printer November 11, 2015 05:54PM |
Re: Large-scale 3d printer November 11, 2015 11:53PM |
Re: Large-scale 3d printer November 12, 2015 01:00AM |
bonmotwang
Hi Val
The thread is in my signature.
Understood that if the only heat source is the heated bed, there is no too much of problem.
I have no concern about that in my design either.
I am just thinking ahead if I make an enclosure to get the internal chamber to 60C. Then the problem may show up in some ways.
Re: Large-scale 3d printer November 12, 2015 01:02AM |
Slaghton
Just from thinking this over while taking the time to read the thread, I think it might be better to just have 4 printers with a decent size and split your 3d model so you can print multiple parts at once. It's like have a printer running 4x as fast if you don't mind piecing them together later. Ex: running a computer program designed with multithreading/multicore support for higher performance.. Though, 1 whole printed object could be more structurally sound.
Re: Large-scale 3d printer November 12, 2015 03:20AM |
Re: Large-scale 3d printer November 12, 2015 09:06AM |
val c.
bonmotwang
Hi Val
Hi bonmotwang,
I am still learning the ropes with regards to this forum and the way it works. Thank you for the tip about your thread.
I have an idea about how I could make an enclosure so that the outside frame of my printer stays, well, outside. I have about 65 mm gap between the platform and the frame, which I could use to build just that. Not there yet, but when I will have some drawings, I will post them here.
Re: Large-scale 3d printer November 12, 2015 11:27AM |
