How do I complete this hot end build?
Posted by Anonymous User
Anonymous User
December 09, 2011 10:47AM
I'm building a Prusa Mendel , with Wades' geared extruder. I bought a harware kit from the reprapkitstore, including:
"RepRap Hot End Kit
Contains
Brass nozzle 0.5mm for 3mm filament.
PTFE insulator
PEEK support block
Brass Heater block"
(I've also separately purchased a thermistor and a supply of 3mm filament)
I'm not quite sure what I have to do to complete this part of the build.
here's a pic:
the bit touched by the screwdriver is loose in that it can slide up & down - so obviously not right at present
I've looked around on the web but not found some clear steps/instructions.
So... what do I need to do to finish this part of the build?
Thanks in advance.
Mike
Re: How do I complete this hot end build?
December 09, 2011 10:55AM
Hello,
You need 2 3mm threaded support rods to hold the PEEK block up tight against the nozzle. The support rods need to go up through the extruder. The idea is that the PEEK block is pulled tight against the nozzle and relieves the PTFE of any stress.
Regards,
Brian Reifsnyder
[www.hotends.com]
December 09, 2011 10:59AM
This should answer all your Q's
[reprap.org]
Dsmiling smiley
Anonymous User
December 09, 2011 11:06AM
Two good replies in 12 minutes - that's great guys, thanks again.
Mike
December 09, 2011 11:56AM
That nozzle is designed for Adrian's extruder, not Wade's. You will need an adapter plate under the extruder for the bolts.
Anonymous User
December 09, 2011 12:37PM
Nophead:
Yes I've had some fun figuring out what to do! I'll probably cut an adaptor out of some ali.
Meanwhile can I ask: is it ok to use heat sink compound to help hold the power resisitor (and maybe the thermistor)
in the barrel?
Edit:
oops.. asked a question before doing a search first! Looks like the answer is yes:
Q re thermistor mounting
Edited 1 time(s). Last edit at 12/09/2011 01:34PM by 3D2B.
December 09, 2011 03:56PM
I use heat resistant silicone on mine as thermal paste doesn't go hard, some people use fire cement I think too
__________________________________________________________________________
Experimenting in 3D in New Zealand
Anonymous User
December 11, 2011 03:07AM
Nophead:
Thanks again for the info. I found a couple of ali parts in the workshop that looked like they could work.
To all, if anyones interested, here's a pic of my hack using those:
The tip of the screwdriver points to a recess for a M4 nut. Theres another opposite side of the ptfe barrel.
I haven't used those recesses and cant see their purpose - what are they for?
Mike
Edited 1 time(s). Last edit at 12/11/2011 03:23AM by 3D2B.
December 11, 2011 05:56AM
Nice solution!
The m4 holes you are pointing at are for mounting the extruder cold end to the carriage.
-Nudel
Blog with RepRap Comic
December 11, 2011 07:27AM
You can mount the extruder inline or at right angles to the x axis. One gives more Z movement and the other more X movement.
