Gettin Started
April 12, 2008 01:33AM
Thinking about putting a fabber together for giggles...the big thing Im curious about is, how good are they detail wise? I do a fair amount of stuff with minatures(28mm-32mm scale for infantry), and was curious as to if a reprap can be expected to put out good detail on 'em. Also, how much does it typically cost to operate one, in parts and material?
Thanks. =)
Re: Gettin Started
April 12, 2008 07:05AM
Hi Travis,
The RepRap is stated to have 0.1 mm resolution (0.004 inch).
For the costs, there's an calculator. It may seem rather high, but if you consider each kg that you fab that expensive, you should understand that the cost of the machine AND replacement parts are already in it, also the proportion of the rent that comes from the room it takes up. Also, the 'wage' you want to earn for your time should be set to low when it's a hobby of yours.
[members.axion.net]
When you upgrade the RepRap in about a year, expect the design to need less maintenance and perhaps being able to recycle parts by then.
Re: Gettin Started
April 12, 2008 11:12AM
Upon looking at the calculator, the two costs Im interested in(replacement parts and materials) are reasonable. Im not bothering with stuff like rent, labor hours, etc, since this is really more of a hobby than a business.
.1mm is great plenty. How does it deal with overhangs? Fill of some other material?
I figure, at a minimum, some of the more expensive parts, like the arduino, and the stepper motors will be reusable in future designs, so Im not terribly worried about that, and Im certainly willing to do a fair bit of tinkering with it.
Re: Gettin Started
April 12, 2008 12:10PM
"How does it deal with overhangs? Fill of some other material? "
It doesn't ... yet.
Re: Gettin Started
April 12, 2008 02:18PM
ErikDeBruijn
That number is a bit deceiving. While the RepRap may have positional accuracy to 0.1mm, the filament it extrudes is on the order of 0.5mm, which means you won't be able to create any features smaller than that. Nophead has also measured noticeable warping on test blocks at the same scale you're talking about - see his blog for details. [hydraraptor.blogspot.com]
0.5mm is still really tiny in my book, but I'm not planning on printing out small highly detailed figurines.
Re: Gettin Started
April 12, 2008 03:34PM
"0.5mm is still really tiny in my book, but I'm not planning on printing out small highly detailed figurines"
Hell! Make 'em bigger! spinning smiley sticking its tongue out
Re: Gettin Started
April 12, 2008 03:41PM
I think that at this stage the reprap is more of a function design printer. It basically will print something that can perform a function, albeit the piece might look like a blob. I would suggest printing the negative for you models, because then the warping can be better controlled and the overhangs can instead become valleys.
Jay
Re: Gettin Started
April 13, 2008 12:59AM
Well, Im constrained by size to a certain scale, but .5mm is still sufficient detail, in my book. Im ok with minor excess material, so long as it isn't irrepairable...you get flash with anything, be it injection molding or casting with resin.
I could do a negative, certainly, but that leaves me with actually producing the models by hand/some other machine. An improvement over sculpting them individually, but still not great. Alternatively, I can do them in chunks and put them together with plastic glue, and experiment with adding a second head to add fill material or something. Any resources out there for adding a second head to one of these?
I believe Im going with arduino electronics, not certain on the material yet...any other big decisions before I start ordering bits?
Re: Gettin Started
April 13, 2008 01:09AM
Remember that this is in the experimental stage.
Re: Gettin Started
April 13, 2008 10:12PM
Well, better experimental than paying 2k+ for a fabber...Several hundred is reasonable for a machine I only intend to use as a hobby, but I've been unable to find any better option at anywhere close to the price.
Re: Gettin Started
April 13, 2008 10:54PM
> close to the price.
"Experimental" means that you need to be willing to spend several hundred dollars (I'm budgeting $1000 for mine, to stay on the safe side) on a machine that you may or may not actually be able to get working.
Of course, things are looking up right now, and if you're willing to put some time into this project, go for it! Many people in the last month or two have begun to put these kits together and are reporting successes.
Re: Gettin Started
April 14, 2008 01:11AM
I spent less than a $1000 on my first machine and the schools machine will cost less than mine. I'd say your grand will do you very well Kyle.
Demented
Re: Gettin Started
April 14, 2008 03:40AM
Hi Travis,
Indeed the reprap economics calculator:
[members.axion.net]
is aimed at business use. I wasn't thinking of hobby use when I wrote it, but after your comment I realized it'd be a good idea to add options for hobby use, so I added the explanation:
"For home use, when labor and rent are effectively zero, choose Hobby (0$ / hour) in the Labor Rate pop up menu, and Unused Space (0$ / square meter / month) in the Rent pop up menu."
and the corresponding pop up menus.
Cheers,
Enrique
