[Solved] Prusa X and Y hits endstop twice before stopping
Posted by Anonymous User
Anonymous User
December 30, 2011 02:36PM
I'm in the process of a Prusa build. Mechanical endstops, the small 'morse key' rocker type.
I now have my steppers moving on all 3 axes & on the extruder.
When I test 'home' for the X axis , the mechanics moves along , touches the switch as expected , then moves away about an inch, comes back again then stops.
Same process for the switch on Y axis.
(The Z axis switch is not ready to test yet).
Is this normal? If not is it a problem / any ideas what the cause is?
Thanks in advance.
Mike
Reprap Prusa
RAMPS 1.4
Pronterface
Edited 1 time(s). Last edit at 12/31/2011 04:32AM by 3D2B.
Re: Prusa X and Y hits endstop twice before stopping
December 30, 2011 03:49PM
Mine does this, so i assume its okay, as long as it returns to the spot its supposed to be in.
December 30, 2011 04:19PM
All three axis woke that way on mine.
Seems normal.
December 30, 2011 05:23PM
This is written in the firmware home command. It is an attempt to make the end stop position more accurate and is common on most machine tools. The axis advances quickly to the end stop, then retreats a little then advances more slowly to the stop which makes a more accurate measurement. Its a better way than simply advancing towards the end stops at slow speed as this would make the homing command slow, particularly on large machines.
December 30, 2011 05:36PM
martinprice2004 got it.
This is written into the firmware, I'd imagine with mechanical endstops in mind, because they can have a variance of about +/- .1 mm (if I recall correctly). Advance very slowly back into the endstop helps to alleviate this problem.
If you scour the code in your firmware I'm sure you can find the lines that govern this action. Hope this helps.
bdc
Stay calm out there.
December 31, 2011 01:03AM
I use optical sensors and they do the 2 bounce thing as well, described by bdcannon above is exactly what mine does
__________________________________________________________________________
Experimenting in 3D in New Zealand
Anonymous User
Re: [Solved] Prusa X and Y hits endstop twice before stopping
December 31, 2011 04:35AM
That's great guys, makes sense. Thanks.
Mike
December 31, 2011 12:16PM
In marlin I have you can change the seek distance in configuration.h line ~234-237.
//homing hits the endstop, then retracts by this distance, before it tries to slowly bump again:
#define X_HOME_RETRACT_MM 5
#define Y_HOME_RETRACT_MM 5
#define Z_HOME_RETRACT_MM 2
I don't see the option in sprinter, but the version I have is a few months old.
-Nudel
Blog with RepRap Comic
December 31, 2011 09:23PM
kliment Sprinter
if((home_all_axis) || (code_seen(axis_codes[0]))) {
if ((X_MIN_PIN > -1 && X_HOME_DIR==-1) || (X_MAX_PIN > -1 && X_HOME_DIR==1)){
current_position[0] = 0;
destination[0] = 1.5 * X_MAX_LENGTH * X_HOME_DIR;
feedrate = homing_feedrate[0];
prepare_move();
destination[0] = -5 * X_HOME_DIR;
prepare_move();
destination[0] = 10 * X_HOME_DIR;
prepare_move();
current_position[0] = (X_HOME_DIR == -1) ? 0 : X_MAX_LENGTH;
destination[0] = current_position[0];
feedrate = 0;
This is in the G28 "Home all" command. it attempts to go to -5 so it stops at the end stop, then back to +10 then homes again. It repeats a similar thing for the other axes. Unfortunately it doesn't seem to do the second homing any slower, so this really defeats the object of doing it as far as I can tell.
