PLA, Fills yesterday, but not today....
December 30, 2011 04:35PM
Noob, trying hard.
Prusa Mendel using Sfact, Pronterface and Sprinter.
Two days ago, I was printing Stars and/or 20mm cubes to dial in the Extrusion width on my .34 nozzle.
All the prints were working fine, except seemed slightly over stuffed at .25 height and .40 extrusion width.
Today, I was going to try .42 and/or .38 width, but I can't get the unit to fill past the second layer. The PLA just stops coming out of the nozzle consistently. sad smiley
Even going back to .40 it fails to fill.
I haven't changed the nozzle temp 200 on heater block. And .40 on bed. (Thermister is taped to glass top)
Now I've heard that printing in a cool basement can be problematic, and the only outside change, is we finally got snow here. smiling smiley
As a test, I tried extruding 50mm and other than it sticking to the nozzle at times, seemed to extrude fine. Although slower than the print.
Ideas, suggestions welcome.
Does ABS have simulator problems?
Re: PLA, Fills yesterday, but not today....
December 30, 2011 05:47PM
Try printing slower. Maybe extruder can't keep up.
December 30, 2011 06:18PM
Also check the hobbed bolt for clogged teeth, and extruder motor for loose gear.
-Nudel
Blog with RepRap Comic
December 30, 2011 06:36PM
It might be useful to know which hot end design you are using.
You need to determine what the real culprit is.
1. Using too high a temperature, and/or thermal barrier hole too narrow.
PLA in particular expands quite a bit when heated near the melting point. It also becomes very soft long before it melts. If the thermal barrier tube diameter is too narrow, the filament can seize against the walls as it warms up.
To test for this condition, remove the hobbed bolt, and try pushing filament through by hand. If the temperature is OK, you should be able to push through with ease. If you cannot easily push the filament through, try pulling it back out. If it is stuck, then your filament has seized in the termal barrier. If you are brave enough, try drilling the barrier out in diameter increments of 0.5mm. You should not need to exceed 4.0mm diameter.
DO NOT proceed to adjust roller bearing pressure against the hobbed bolt until you can push filament through by hand. You will never solve the problem.
2. Using too low a temparature.
I don't think this is the case. Easy enough to check, right?
3. Bearing against the hobbed bolt too loose.
If you were able to push filament through by hand with ease, and if the hobbing is full of plastic dust, then your roller bearing is not tight enough against the filament. Tighten it beyond the point where the big gear can move, and slowly back off the pressure until the filament begins extruding.
4. Bearing against the hobbed bolt too tight.
If the bearing is too tight, the stepper motor should stall, and lash the big extruder gear backwards at regular intervals when you try to extrude. Slowly back off the pressure until the filament begins extruding.
December 30, 2011 10:01PM
Wish I knew how! Too many variables in the Speed tab to play with.
December 30, 2011 10:05PM
We Have a Winner!!! smiling smiley
I love the reversed hobbed bolt I got with my Plastic parts. Nice open groves with good sized teeth.
However, After removing the plastic, I was surprised how much plastic had actually managed to get lodged in there.
I'm sure that was causing slippage.
Thanks.
Komb'
December 30, 2011 10:22PM
Answering this one because I like it. smiling smiley
> you are using.
MixShop design?
It's a PTFE rod with a threaded brass rod. both 3mm holed. Aluminum heater block threaded on then brass acorn nut with .34mm hole.
Hand assembled by myself.
This is why I like this post.
> diameter.
Had this sort of problem before. Had the rod too far up the PTFE and managed to get hot plastic stuck to the extruder. tongue sticking out smiley
Before I removed the plastic, I disengaged the motor and pushed on the filiment, the bolt/gear turned and plastic came out the print end. smiling smiley
Then I pulled the plastic out, without any trouble.
> the problem.
Good advice, I'm sure.
> check, right?
Right! Been there, done that.
I once thought I would be cleaver, and would leave the roller loose enough to push new plastic past it. (until I can print an accessible extruder...) I've learned that is Not the way to go. smiling smiley Wasn't sure how tight to make it though.
It is set much tighter now. Thanks.
Komb'
