8 mm Rods: Shafting Steel vs. Stainless Steel vs. Mild Steel January 10, 2012 06:15PM |
Re: 8 mm Rods: Shafting Steel vs. Stainless Steel vs. Mild Steel January 10, 2012 08:46PM |
Re: 8 mm Rods: Shafting Steel vs. Stainless Steel vs. Mild Steel January 10, 2012 10:54PM |
Re: 8 mm Rods: Shafting Steel vs. Stainless Steel vs. Mild Steel January 11, 2012 04:46AM |
Re: 8 mm Rods: Shafting Steel vs. Stainless Steel vs. Mild Steel January 11, 2012 05:52AM |
Re: 8 mm Rods: Shafting Steel vs. Stainless Steel vs. Mild Steel January 11, 2012 08:04AM |
pretty well all grades of "steel" (mild, stainless, hardened tool steel, etc) have pretty the same stiffness / deflection characteristics as each other
If it's wear that you are concerned about, then hardness is what matters.
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: 8 mm Rods: Shafting Steel vs. Stainless Steel vs. Mild Steel January 11, 2012 10:03AM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: 8 mm Rods: Shafting Steel vs. Stainless Steel vs. Mild Steel January 11, 2012 10:27AM |
Re: 8 mm Rods: Shafting Steel vs. Stainless Steel vs. Mild Steel January 11, 2012 11:24AM |
Re: 8 mm Rods: Shafting Steel vs. Stainless Steel vs. Mild Steel January 11, 2012 01:52PM |
Re: 8 mm Rods: Shafting Steel vs. Stainless Steel vs. Mild Steel January 11, 2012 02:12PM |
Re: 8 mm Rods: Shafting Steel vs. Stainless Steel vs. Mild Steel January 11, 2012 04:51PM |
Re: 8 mm Rods: Shafting Steel vs. Stainless Steel vs. Mild Steel January 11, 2012 05:57PM |
Re: 8 mm Rods: Shafting Steel vs. Stainless Steel vs. Mild Steel January 11, 2012 08:28PM |
Re: 8 mm Rods: Shafting Steel vs. Stainless Steel vs. Mild Steel January 12, 2012 06:55PM |
Re: 8 mm Rods: Shafting Steel vs. Stainless Steel vs. Mild Steel January 12, 2012 07:33PM |
Re: 8 mm Rods: Shafting Steel vs. Stainless Steel vs. Mild Steel January 14, 2012 01:15PM |
Re: 8 mm Rods: Shafting Steel vs. Stainless Steel vs. Mild Steel January 14, 2012 02:38PM |
Re: 8 mm Rods: Shafting Steel vs. Stainless Steel vs. Mild Steel January 14, 2012 10:50PM |
Admin Registered: 15 years ago Posts: 1,470 |
Help improve the RepRap wiki!
Just click "Edit" in the top-right corner of the page and start typing. Anyone can edit the wiki! |
Re: 8 mm Rods: Shafting Steel vs. Stainless Steel vs. Mild Steel January 15, 2012 03:09AM |
Re: 8 mm Rods: Shafting Steel vs. Stainless Steel vs. Mild Steel January 15, 2012 03:35AM |
Re: 8 mm Rods: Shafting Steel vs. Stainless Steel vs. Mild Steel January 24, 2015 10:07PM |
Re: 8 mm Rods: Shafting Steel vs. Stainless Steel vs. Mild Steel January 24, 2015 10:52PM |
Skypuppet
So after shopping McMaster Carr again (no this is not an advertisement), I found some reasonably priced "type 17-4 ph stainless" precicion ground rod. Not cheap, but not horribly expensive either. I'm not trying to make margins on my machines either, so a few extra bucks is money well spent.
Re: 8 mm Rods: Shafting Steel vs. Stainless Steel vs. Mild Steel January 25, 2015 10:23AM |
Admin Registered: 11 years ago Posts: 3,096 |
Re: 8 mm Rods: Shafting Steel vs. Stainless Steel vs. Mild Steel January 25, 2015 11:57AM |
Re: 8 mm Rods: Shafting Steel vs. Stainless Steel vs. Mild Steel January 25, 2015 12:55PM |
Re: 8 mm Rods: Shafting Steel vs. Stainless Steel vs. Mild Steel January 25, 2015 08:52PM |
Re: 8 mm Rods: Shafting Steel vs. Stainless Steel vs. Mild Steel January 26, 2015 05:00AM |
Re: 8 mm Rods: Shafting Steel vs. Stainless Steel vs. Mild Steel January 26, 2015 11:34AM |
Zavashier
Ball bearings and aluminium goes wrong because the balls digs into aluminium.
Re: 8 mm Rods: Shafting Steel vs. Stainless Steel vs. Mild Steel January 26, 2015 05:33PM |
