Ooozing and strands problem(s)
Posted by 3D2B
February 04, 2012 06:40AM
Once heated up, my Prusa Mendel oozes filament before I start a print - is this normal? If not what can needs to be done to stop it?
I tried the pyramid print and got a result similar to the initial picture in this thread
Similar result
I too am getting the thin strands of PLA between the corner 'struts' of the pyramid.
I assumng likely the oozing & the stranding are linked.
What can be done to correct the stranding problem?
Thanks in advance
Mike
Using PLA. Brass nozzle 0.5mm for 3mm filament.
Prusa Mendel /Parcan Mk 2/1280 RAMPS 1.4/PC XP OS/Pronterface/Slic3r
In the UK, down south & over to the left you'll find the West of England RUG.
For details, visit tiny.cc/woereprap or tiny.cc/woerug
Re: Ooozing and strands problem(s)
February 04, 2012 09:00AM
When left heated and idle the hotend will drool out the molten filament in the nozzle, there is no way to prevent this. You counter it by priming the nozzle before you start the print, and/or by printing a skirt.
Stranding is fixed by dialling in retraction and temperature perfectly.
-Nudel
Blog with RepRap Comic
February 04, 2012 12:20PM
Ok thanks Nudel.
Looks like the pronterface is already printing a skirt.
Pronterface has the reverse (= retract?) default as 1mm/min. I upped it to 2 & the quality got a lot worse(insufficient filament)
very 'whispy' print. Presumably 0 = no retract, not a good idea.
I'll have a go with the temperature settings.
Mike
February 04, 2012 06:59PM
As you found out, pulling back too far is bad. It's better to increase the speed of retraction than increasing the distance retracted. I think I saw nophead say elsewhere that 1.8mm is about the most you would want for a bowden cable, so I suggest you consider that an absolute upper bound. The plastic parts for my first working Mendel came from him, and I consider the quality of his prints to be the bar I try to meet. I usually have the retraction distance between 0.8 and 1.0 depending on the spool of filament I'm using...
February 04, 2012 09:06PM
I think from memory using SF41 and Repsnaper I use 30mm/sec and 2mm of retract, can't remember exactly and not at home to check the settings on my desktop
__________________________________________________________________________
Experimenting in 3D in New Zealand
