So why not build a base and extrude it in an upright position instead of on its side? Finishing is a process in and of itself anyway. Even molded plastic parts arent perfect until they are machined.
A pet project of mine is to construct an engine using plastic parts fabbed from a reprap and cast with the lost wax process. One of the more complex parts is the cranshaft, which cannot be constructed unless it has some support.
However I can construct it on its end so that I can fab almost all of it with one CAD model. The angular offest of the beam from the main to crank journal would ordinarilly be +/- 30*, obvously needing support if fabbed on its side. Fabbing it on its end solves that problem nicely because the +/- 30* is on the vertical plane, which never exceeds the 45* overhang problem.
For complex parts like this, what about modifying the program that interprets the CAD model such that a 3d space around the model is drawn, and everything in that space that is not part of the model gets assigned to filler material?
