I have made a JDM progammer and now tryinig to test it by the following steps which I got from:
www.reprap.org]
THESE ARE THE TESTING STEPS:
If you're using Windows and ic-prog (which I'm using!), then go to Settings | Hardware Check. Plug in the programmer and leave the IC socket empty. You should observe the following:
1 Using a multimeter, measure the voltage on the IC socket between pin 5 (-) and pin 14 (+). It should be just below 5V.
2 When you tick Enable Data Out, the Data In checkbox should also become ticked (and vice versa). You cannot directly tick the Data In checkbox.
3 Measure the voltage between pin 5 (-) and pin 13 (+). It should read around -2V to -2.5V. When you tick the Enable Data Out checkbox, it should swing to 4.5V to 5V.
4 Measure the voltage between pin 5 (-) and pin 12 (+). Tick the Enable Clock box and it should go to +5V (or a little more). Untick it and it should return to 0V (actually about -0.5V to -0.8V).
5 Measure the voltage between pin 5 (-) and pin 4 (+). Tick the Enable MCLR box and it should go to +12V. Untick it and it should return to 0V (actually about -0.5V).
The thired step, bolded letters is what I am getting as +3.15V which should be -2V to -2.5V, after that every thing is right, I mean every thing except this bolded letters only not the whole steps!!
PLEASE HELP ME!!
I used 100uF/63V insted of 40V and 22uF/25V insted of 16V but I don't think that can cause problem or can it? (Exact values of capacitor voltage is not available!)
Give me schematic if I need to make some interface, I'm a layman. Please don't just tell me to search over net, I'm tired of that (from last two weeks I'm trying to fix this) and now I want to concentrate on my collage studies, pleazzzz... help me I'm sick of asking this on many forums, hope RepRap will help as I started it from here.
