Not printing very well... please help spinning smiley sticking its tongue out
March 01, 2012 02:27PM
Hello,
I have a longboat prusa. When i get it to print, the printer head knocks the first layer either on the second or still on the first and pushes it. So i cant print at the moment because of this. are there any tips anyone could give. i am using slic3r - are there any settings i could tweak?
Thanks
simon
Edited 1 time(s). Last edit at 03/02/2012 12:26PM by simonhoughton.
Re: Not printing very well... please help spinning smiley sticking its tongue out
March 01, 2012 04:07PM
First thing is to level your bed. If the bed surface is not absolutely flat, or close to it, you will need to use rafting on your prints.
Second thing is that you need to calibrate X, Y, and Z so that when you command an axis to move 100mm it moves exactly 100mm +/- 0.2mm
Third is to calibrate your extruder. Search for extrusion calculator.
March 02, 2012 12:26PM
Thanks i will try that :-)
