RepRap Featured in HackaDay
Posted by redskinsjbs
Re: RepRap Featured in HackaDay
June 02, 2008 07:49PM
We could do those pieces, check out what the fab@home guys did: [fabathome.org]
VDX
June 03, 2008 03:20AM
Hi Gene Hacker,
i followed the f@h-development the last year too, but either f@h nor reprap can do the finishing - the surface-accuracy is much to coarse sad smiley
The best try in the actual stage would be lost-cast-moulding with fields metall or lowtemp-wax (which didn't stick to epoxy) and mould with epoxy ...
Viktor
VDX
June 20, 2008 07:50AM
... an update for 3D-stacking chess-pieces:
Milled from 3mm Foamalux, total height 4cm.
Actually my sons insist in building 'personalized' figurines for their favorite boardgames - when i'll do this, it would mean some months designing and milling eye popping smiley
Viktor
June 20, 2008 12:49PM
> Viktor
If you're going to make something out of metal it would be really cool to print your own monopoly pieces.
VDX
June 20, 2008 04:51PM
... i've designed a complete set of stacked pieces:
If someone is interested in milling or fabbing them i'll append the DXF-output and when converted for my mill there would be optimized DXF, HPGL or NCP ... i'm searching a GCode-converter ...
Viktor
open | download - Schach2-Komplett.zip (104.3 KB)
VDX
June 25, 2008 02:25PM
... and here the milled set of mini-pieces:
I used a sample-sheet of laminate with 0.8mm thickness and milled with a 1mm-head.
Viktor
VDX
September 06, 2008 03:03PM
... update - my youngest son wanted a flower for his butterfly, so i milled a flower-chip with the same parameters.
...flower in pieces:
... and assembled:
Viktor
VDX
September 19, 2008 03:48PM
... now the other evolved to 3D-chips.
DarthVaders mask (milled from black POM and floor-laminate):
Viktor
