Configuration.h help Gen6
Posted by mxcobra
March 09, 2012 07:03PM
I'm having trouble with getting the firmware working on my prusa...
Im running Gen6 with sprinter firmware.. Specs as follows
NEMA17 1.8 motors
Lulzbot hot end
Mechanical end stops..
I have tried all kinds of different settings.. I can get all 3 axis to move in both directions.. But the only one that would see the end stop was the X axis...
I just want to get this thing settled down so I can do the calibration... But the end stops are kicking me right in the nuts !!
Here is a copy of the config file :
#ifndef CONFIGURATION_H
#define CONFIGURATION_H
// BASIC SETTINGS: select your board type, thermistor type, axis scaling, and endstop configuration
//// The following define selects which electronics board you have. Please choose the one that matches your setup
// MEGA/RAMPS up to 1.2 = 3,
// RAMPS 1.3 = 33
// Gen6 = 5,
// Sanguinololu up to 1.1 = 6
// Sanguinololu 1.2 and above = 62
// Teensylu (at90usb) = 8
// Gen 3 Plus = 21
// gen 3 Monolithic Electronics = 22
// Gen3 PLUS for TechZone Gen3 Remix Motherboard = 23
#define MOTHERBOARD 5
//// Thermistor settings:
// 1 is 100k thermistor
// 2 is 200k thermistor
// 3 is mendel-parts thermistor
// 4 is 10k thermistor
// 5 is ParCan supplied 104GT-2 100K
// 6 is EPCOS 100k
// 7 is 100k Honeywell thermistor 135-104LAG-J01
#define THERMISTORHEATER 1
#define THERMISTORBED 1
//// Calibration variables
// X, Y, Z, E steps per unit - Metric Prusa Mendel with Wade extruder:
float axis_steps_per_unit[] = {80, 80, 3200/1.25,700};
// Metric Prusa Mendel with Makergear geared stepper extruder:
//float axis_steps_per_unit[] = {80,80,3200/1.25,1380};
// MakerGear Hybrid Prusa Mendel:
// Z axis value is for .9 stepper(if you have 1.8 steppers for Z, you need to use 2272.7272)
//float axis_steps_per_unit[] = {104.987, 104.987, 4545.4544, 1487};
//// Endstop Settings
#define ENDSTOPPULLUPS // Comment this out (using // at the start of the line) to disable the endstop pullup resistors
// The pullups are needed if you directly connect a mechanical endswitch between the signal and ground pins.
//If your axes are only moving in one direction, make sure the endstops are connected properly.
//If your axes move in one direction ONLY when the endstops are triggered, set [XYZ]_ENDSTOP_INVERT to true here:
const bool X_ENDSTOP_INVERT = false;
const bool Y_ENDSTOP_INVERT = false;
const bool Z_ENDSTOP_INVERT = false;
// This determines the communication speed of the printer
#define BAUDRATE 19200
// Comment out (using // at the start of the line) to disable SD support:
#define SDSUPPORT
// Uncomment to make Sprinter run init.g from SD on boot
//#define SDINITFILE
//// ADVANCED SETTINGS - to tweak parameters
#include "thermistortables.h"
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define E_ENABLE_ON 0
// Disables axis when it's not being used.
const bool DISABLE_X = false;
const bool DISABLE_Y = false;
const bool DISABLE_Z = true;
const bool DISABLE_E = false;
// Inverting axis direction
const bool INVERT_X_DIR = false;
const bool INVERT_Y_DIR = false;
const bool INVERT_Z_DIR = true;
const bool INVERT_E_DIR = false;
//// ENDSTOP SETTINGS:
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR -1
const bool min_software_endstops = false; //If true, axis won't move to coordinates less than zero.
const bool max_software_endstops = true; //If true, axis won't move to coordinates greater than the defined lengths below.
const int X_MAX_LENGTH = 200;
const int Y_MAX_LENGTH = 200;
const int Z_MAX_LENGTH = 100;
//// MOVEMENT SETTINGS
const int NUM_AXIS = 4; // The axis order in all axis related arrays is X, Y, Z, E
float max_feedrate[] = {200000, 200000, 240, 500000};
float homing_feedrate[] = {1500,1500,120};
bool axis_relative_modes[] = {false, false, false, false};
// Min step delay in microseconds. If you are experiencing missing steps, try to raise the delay microseconds, but be aware this
// If you enable this, make sure STEP_DELAY_RATIO is disabled.
//#define STEP_DELAY_MICROS 1
// Step delay over interval ratio. If you are still experiencing missing steps, try to uncomment the following line, but be aware this
// If you enable this, make sure STEP_DELAY_MICROS is disabled. (except for Gen6: both need to be enabled.)
//#define STEP_DELAY_RATIO 0.25
// Comment this to disable ramp acceleration
#define RAMP_ACCELERATION
//// Acceleration settings
#ifdef RAMP_ACCELERATION
// X, Y, Z, E maximum start speed for accelerated moves. E default values are good for skeinforge 40+, for older versions raise them a lot.
float max_start_speed_units_per_second[] = {25.0,25.0,0.2,10.0};
long max_acceleration_units_per_sq_second[] = {1000,1000,50,10000}; // X, Y, Z and E max acceleration in mm/s^2 for printing moves or retracts
long max_travel_acceleration_units_per_sq_second[] = {500,500,50,500}; // X, Y, Z max acceleration in mm/s^2 for travel moves
#endif
// Machine UUID
// This may be useful if you have multiple machines and wish to identify them by using the M115 command.
// By default we set it to zeros.
char uuid[] = "00000000-0000-0000-0000-000000000000";
//// AD595 THERMOCOUPLE SUPPORT UNTESTED... USE WITH CAUTION!!!!
//// PID settings:
// Uncomment the following line to enable PID support. This is untested and could be disastrous. Be careful.
//#define PIDTEMP 1
#ifdef PIDTEMP
#define PID_INTEGRAL_DRIVE_MAX 80 // too big, and heater will lag after changing temperature, too small and it might not compensate enough for long-term errors
#define PID_PGAIN 2560 //256 is 1.0 // value of X means that error of 1 degree is changing PWM duty by X, probably no need to go over 25
#define PID_IGAIN 64 //256 is 1.0 // value of X (e.g 0.25) means that each degree error over 1 sec (2 measurements) changes duty cycle by 2X (=0.5) units (verify?)
#define PID_DGAIN 4096 //256 is 1.0 // value of X means that around reached setpoint, each degree change over one measurement (half second) adjusts PWM by X units to compensate
// magic formula 1, to get approximate "zero error" PWM duty. Take few measurements with low PWM duty and make linear fit to get the formula
#define HEATER_DUTY_FOR_SETPOINT(setpoint) ((int)((187L*(long)setpoint)>>8)-27) // for my makergear hot-end: linear fit {50,10},{60,20},{80,30},{105,50},{176,100},{128,64},{208,128}
// magic formula 2, to make led brightness approximately linear
#define LED_PWM_FOR_BRIGHTNESS(brightness) ((64*brightness-1384)/(300-brightness))
#endif
// Change this value (range 1-255) to limit the current to the nozzle
#define HEATER_CURRENT 255
// How often should the heater check for new temp readings, in milliseconds
#define HEATER_CHECK_INTERVAL 500
#define BED_CHECK_INTERVAL 5000
// Comment the following line to enable heat management during acceleration
#define DISABLE_CHECK_DURING_ACC
#ifndef DISABLE_CHECK_DURING_ACC
// Uncomment the following line to disable heat management during moves
//#define DISABLE_CHECK_DURING_MOVE
#endif
// Uncomment the following line to disable heat management during travel moves (and extruder-only moves, eg: retracts), strongly recommended if you are missing steps mid print.
// Probably this should remain commented if are using PID.
// It also defines the max milliseconds interval after which a travel move is not considered so for the sake of this feature.
#define DISABLE_CHECK_DURING_TRAVEL 1000
//// Temperature smoothing - only uncomment this if your temp readings are noisy (Gen6 without EvdZ's 5V hack)
//#define SMOOTHING
//#define SMOOTHFACTOR 16 //best to use a power of two here - determines how many values are averaged together by the smoothing algorithm
//// Experimental watchdog and minimal temp
// The watchdog waits for the watchperiod in milliseconds whenever an M104 or M109 increases the target temperature
// If the temperature has not increased at the end of that period, the target temperature is set to zero. It can be reset with another M104/M109
//#define WATCHPERIOD 5000 //5 seconds
// Actual temperature must be close to target for this long before M109 returns success
//#define TEMP_RESIDENCY_TIME 20 // (seconds)
//#define TEMP_HYSTERESIS 5 // (C°) range of +/- temperatures considered "close" to the target one
//// The minimal temperature defines the temperature below which the heater will not be enabled
#define MINTEMP 5
//// Experimental max temp
// When temperature exceeds max temp, your heater will be switched off.
// This feature exists to protect your hotend from overheating accidentally, but *NOT* from thermistor short/failure!
// You should use MINTEMP for thermistor short/failure protection.
#define MAXTEMP 275
// Select one of these only to define how the nozzle temp is read.
#define HEATER_USES_THERMISTOR
//#define HEATER_USES_AD595
//#define HEATER_USES_MAX6675
// Select one of these only to define how the bed temp is read.
#define BED_USES_THERMISTOR
//#define BED_USES_AD595
//This is for controlling a fan to cool down the stepper drivers
//it will turn on when any driver is enabled
//and turn off after the set amount of seconds from last driver being disabled again
//#define CONTROLLERFAN_PIN 23 //Pin used for the fan to cool controller, comment out to disable this function
#define CONTROLLERFAN_SEC 60 //How many seconds, after all motors were disabled, the fan should run
// Uncomment the following line to enable debugging. You can better control debugging below the following line
//#define DEBUG
#ifdef DEBUG
//#define DEBUG_PREPARE_MOVE //Enable this to debug prepare_move() function
//#define DEBUG_BRESENHAM //Enable this to debug the Bresenham algorithm
//#define DEBUG_RAMP_ACCELERATION //Enable this to debug all constant acceleration info
//#define DEBUG_MOVE_TIME //Enable this to time each move and print the result
//#define DEBUG_HEAT_MGMT //Enable this to debug heat management. WARNING, this will cause axes to jitter!
//#define DEBUG_DISABLE_CHECK_DURING_TRAVEL //Debug the namesake feature, see above in this file
#endif
#endif
Edited 1 time(s). Last edit at 03/09/2012 07:06PM by mxcobra.
Re: Configuration.h help Gen6
March 10, 2012 02:17AM
can you also share your pins.h file?
March 10, 2012 06:26AM
It sounds like a hardware fault rather than a firmware problem. Can you plug the X-endstop into the Y and Z axes and see if they react to it?
March 10, 2012 09:53AM
I have extra mechanical endstops... I have tried diffenet ones.. Same thing...
Here is the pins file:
ifndef PINS_H
#define PINS_H
* Arduino pin assignment
* ATMega168
* PC6 1| |28 PC5 (AI 5 / D19)
* (D 0) PD0 2| |27 PC4 (AI 4 / D18)
* (D 1) PD1 3| |26 PC3 (AI 3 / D17)
* (D 2) PD2 4| |25 PC2 (AI 2 / D16)
* PWM+ (D 3) PD3 5| |24 PC1 (AI 1 / D15)
* (D 4) PD4 6| |23 PC0 (AI 0 / D14)
* VCC 7| |22 GND
* GND 8| |21 AREF
* PB6 9| |20 AVCC
* PB7 10| |19 PB5 (D 13)
* PWM+ (D 5) PD5 11| |18 PB4 (D 12)
* PWM+ (D 6) PD6 12| |17 PB3 (D 11) PWM
* (D 7) PD7 13| |16 PB2 (D 10) PWM
* (D 8) PB0 14| |15 PB1 (D 9) PWM
#if MOTHERBOARD == 0
#define KNOWN_BOARD 1
#ifndef __AVR_ATmega168__
#error Oops! Make sure you have 'Arduino Diecimila' selected from the boards menu.
#endif
#define X_STEP_PIN 2
#define X_DIR_PIN 3
#define X_ENABLE_PIN -1
#define X_MIN_PIN 4
#define X_MAX_PIN 9
#define Y_STEP_PIN 10
#define Y_DIR_PIN 7
#define Y_ENABLE_PIN -1
#define Y_MIN_PIN 8
#define Y_MAX_PIN 13
#define Z_STEP_PIN 19
#define Z_DIR_PIN 18
#define Z_ENABLE_PIN 5
#define Z_MIN_PIN 17
#define Z_MAX_PIN 16
#define E_STEP_PIN 11
#define E_DIR_PIN 12
#define E_ENABLE_PIN -1
#define SDPOWER -1
#define SDSS -1
#define LED_PIN -1
#define FAN_PIN -1
#define PS_ON_PIN 15
#define KILL_PIN -1
#define HEATER_0_PIN 6
#define TEMP_0_PIN 0 // MUST USE ANALOG INPUT NUMBERING NOT DIGITAL OUTPUT NUMBERING!!!!!!!!!
#endif
* Sanguino/RepRap Motherboard with direct-drive extruders
* ATMega644P
* (D 0) PB0 1| |40 PA0 (AI 0 / D31)
* (D 1) PB1 2| |39 PA1 (AI 1 / D30)
* INT2 (D 2) PB2 3| |38 PA2 (AI 2 / D29)
* PWM (D 3) PB3 4| |37 PA3 (AI 3 / D28)
* PWM (D 4) PB4 5| |36 PA4 (AI 4 / D27)
* MOSI (D 5) PB5 6| |35 PA5 (AI 5 / D26)
* MISO (D 6) PB6 7| |34 PA6 (AI 6 / D25)
* SCK (D 7) PB7 8| |33 PA7 (AI 7 / D24)
* RST 9| |32 AREF
* VCC 10| |31 GND
* GND 11| |30 AVCC
* XTAL2 12| |29 PC7 (D 23)
* XTAL1 13| |28 PC6 (D 22)
* RX0 (D 8) PD0 14| |27 PC5 (D 21) TDI
* TX0 (D 9) PD1 15| |26 PC4 (D 20) TDO
* INT0 RX1 (D 10) PD2 16| |25 PC3 (D 19) TMS
* INT1 TX1 (D 11) PD3 17| |24 PC2 (D 18) TCK
* PWM (D 12) PD4 18| |23 PC1 (D 17) SDA
* PWM (D 13) PD5 19| |22 PC0 (D 16) SCL
* PWM (D 14) PD6 20| |21 PD7 (D 15) PWM
#if MOTHERBOARD == 1
#if !defined(__AVR_ATmega644P__) && !defined(__AVR_ATmega1284P__)
#error Oops! Make sure you have 'Sanguino' selected from the 'Tools -> Boards' menu.
#endif
#define X_STEP_PIN 15
#define X_DIR_PIN 18
#define X_ENABLE_PIN 19
#define X_MIN_PIN 20
#define X_MAX_PIN 21
#define Y_STEP_PIN 23
#define Y_DIR_PIN 22
#define Y_ENABLE_PIN 19
#define Y_MIN_PIN 25
#define Y_MAX_PIN 26
#define Z_STEP_PIN 29
#define Z_DIR_PIN 30
#define Z_ENABLE_PIN 31
#define Z_MIN_PIN 2
#define Z_MAX_PIN 1
#define E_STEP_PIN 12
#define E_DIR_PIN 16
#define E_ENABLE_PIN 3
#define SDPOWER -1
#define SDSS -1
#define LED_PIN 0
#define FAN_PIN -1
#define PS_ON_PIN -1
#define KILL_PIN -1
#define HEATER_0_PIN 14
#define TEMP_0_PIN 4 //D27 // MUST USE ANALOG INPUT NUMBERING NOT DIGITAL OUTPUT NUMBERING!!!!!!!!!
/* Unused (1) (2) (3) 4 5 6 7 8 9 10 11 12 13 (14) (15) (16) 17 (18) (19) (20) (21) (22) (23) 24 (25) (26) (27) 28 (29) (30) (31) */
#endif
* RepRap Motherboard ****---NOOOOOO RS485/EXTRUDER CONTROLLER!!!!!!!!!!!!!!!!!---*******
#if MOTHERBOARD == 2
#endif
#define Y_ENABLE_PIN 24
#define Z_STEP_PINN 27
#define Z_DIR_PINN 28
#define Z_ENABLE_PIN 29
#define Z_MIN_PIN 30
#define Z_MAX_PIN 31
#define E_STEP_PIN 17
#define SDPOWER -1
#define SDSS 4
#define LED_PIN 0
#define SD_CARD_WRITE 2
#define SD_CARD_DETECT 3
#define SD_CARD_SELECT 4
//our RS485 pins
#define TX_ENABLE_PIN 12
#define RX_ENABLE_PIN 13
//pin for controlling the PSU.
#define PS_ON_PIN 14
#define FAN_PIN -1
#define KILL_PIN -1
#define HEATER_0_PIN -1
#define TEMP_0_PIN -1 // MUST USE ANALOG INPUT NUMBERING NOT DIGITAL OUTPUT NUMBERING!!!!!!!!!
#endif
* Gen3 PLUS
#if MOTHERBOARD == 21
#ifndef __AVR_ATmega644P__
#endif
//x axis pins
#define X_MAX_PIN -1
//y axis pins
#define Y_MAX_PIN -1
//z axis pins
#define Z_STEP_PIN 27
#define Z_DIR_PIN 28
#define Z_MAX_PIN -1
#define E_DIR_PIN 21
#define E_ENABLE_PIN 13
//heaters
//pin for hot end heater
#define HEATER_0_PIN 12
//Pin for heated bed heater
#define HEATER_1_PIN 5
//pin for debugging.
#define DEBUG_PIN -1
//SD card pin
#define SDSS 4
#define SDPOWER -1
#define FAN_PIN -1
#define TEMP_1_PIN 5
#define LED_PIN -1
#endif
* Gen3 Monolithic Electronics
#if MOTHERBOARD == 22
#endif
#define DEBUG_PIN 0
// x axis
#define X_ENABLE_PIN 24 //actually uses Y_enable_pin
// y axes
#define Y_ENABLE_PIN 24 //shared with X_enable_pin
// z axes
//extruder pins
#define E_DIR_PIN 17
#define HEATER_0_PIN 16
#define FAN_PIN -1
//bed pins
#define HEATER_1_PIN -1
#define TEMP_1_PIN -1
#define SDSS -1
#define SDPOWER -1
#define LED_PIN -1
#endif
* Arduino Mega pin assignment
#if MOTHERBOARD == 33
#define MOTHERBOARD 3
#define RAMPS_V_1_3
#endif
//////////////////FIX THIS//////////////
#ifndef __AVR_ATmega1280__
#ifndef __AVR_ATmega2560__
#error Oops! Make sure you have 'Arduino Mega' selected from the 'Tools -> Boards' menu.
#endif
#endif
// uncomment one of the following lines for RAMPS v1.3 or v1.0, comment both for v1.2 or 1.1
// #define RAMPS_V_1_3
// #define RAMPS_V_1_0
#ifdef RAMPS_V_1_3
#define X_STEP_PIN 54
#define X_DIR_PIN 55
#define X_ENABLE_PIN 38
#define X_MIN_PIN 3
#define X_MAX_PIN -1 //2 //Max endstops default to disabled "-1", set to commented value to enable.
#define Y_STEP_PIN 60
#define Y_DIR_PIN 61
#define Y_ENABLE_PIN 56
#define Y_MIN_PIN 14
#define Y_MAX_PIN -1 //15
#define Z_STEP_PIN 46
#define Z_DIR_PIN 48
#define Z_ENABLE_PIN 62
#define Z_MIN_PIN 18
#define Z_MAX_PIN -1 //19
#define E_STEP_PIN 26
#define E_DIR_PIN 28
#define E_ENABLE_PIN 24
#define E_1_STEP_PIN 36
#define E_1_DIR_PIN 34
#define E_1_ENABLE_PIN 30
#define SDPOWER -1
#define SDSS 53
#define LED_PIN 13
#define FAN_PIN 9
#define PS_ON_PIN 12
#define KILL_PIN -1
#define HEATER_0_PIN 10
#define HEATER_1_PIN 8
#define TEMP_0_PIN 13 // ANALOG NUMBERING
#define TEMP_1_PIN 14 // ANALOG NUMBERING
#else // RAMPS_V_1_1 or RAMPS_V_1_2 as default
#define X_STEP_PIN 26
#define X_DIR_PIN 28
#define X_MIN_PIN 3
#define Y_STEP_PIN 38
#define Y_DIR_PIN 40
#define Y_ENABLE_PIN 36
#define Y_MIN_PIN 16
#define Y_MAX_PIN -1 //17
#define Z_STEP_PIN 44
#define Z_DIR_PIN 46
#define Z_ENABLE_PIN 42
#define E_STEP_PIN 32
#define E_DIR_PIN 34
#define E_ENABLE_PIN 30
#define SDPOWER 48
#define SDSS 53
#define LED_PIN 13
#define KILL_PIN -1
#ifdef RAMPS_V_1_0 // RAMPS_V_1_0
#define HEATER_0_PIN 12 // RAMPS 1.0
#define HEATER_1_PIN -1 // RAMPS 1.0
#define FAN_PIN 11 // RAMPS 1.0
#define HEATER_0_PIN 10 // RAMPS 1.1
#define HEATER_1_PIN 8 // RAMPS 1.1
#define FAN_PIN 9 // RAMPS 1.1
#endif
#define TEMP_0_PIN 2 // MUST USE ANALOG INPUT NUMBERING NOT DIGITAL OUTPUT NUMBERING!!!!!!!!!
#define TEMP_1_PIN 1 // MUST USE ANALOG INPUT NUMBERING NOT DIGITAL OUTPUT NUMBERING!!!!!!!!!
#endif
// SPI for Max6675 Thermocouple
#ifndef SDSUPPORT
// these pins are defined in the SD library if building with SD support #define SCK_PIN 52
#define MISO_PIN 50
#define MOSI_PIN 51
#define MAX6675_SS 53
#else
#define MAX6675_SS 49
#endif
#endif
* Duemilanove w/ ATMega328P pin assignment
#if MOTHERBOARD == 4
#ifndef __AVR_ATmega328P__
#error Oops! Make sure you have 'Arduino Duemilanove w/ ATMega328' selected from the 'Tools -> Boards' menu.
#endif
#define X_STEP_PIN 19
#define X_MIN_PIN 17
#define Y_DIR_PIN 7
#define Y_MIN_PIN 8
#define Z_STEP_PIN 13
#define Z_DIR_PIN 3
#define Z_MIN_PIN 4
#define SDPOWER -1
#define SDSS -1
#define LED_PIN -1
#define FAN_PIN 5
#define KILL_PIN -1
#endif
* Gen6 pin assignment
#if MOTHERBOARD == 5
#endif
//x axis pins
//y axis pins
//z axis pins
//extruder pins
#define E_STEP_PIN 4 //Edited @ EJE Electronics 20100715
#define E_DIR_PIN 2 //Edited @ EJE Electronics 20100715
#define E_ENABLE_PIN 3 //Added @ EJE Electronics 20100715
#define TEMP_0_PIN 5 //changed @ rkoeppl 20110410
#define HEATER_0_PIN 14 //changed @ rkoeppl 20110410
#define HEATER_1_PIN -1 //changed @ rkoeppl 20110410
#define SDPOWER -1
#define SDSS 17
#define LED_PIN -1 //changed @ rkoeppl 20110410
#define TEMP_1_PIN -1 //changed @ rkoeppl 20110410
#define FAN_PIN -1 //changed @ rkoeppl 20110410
#define PS_ON_PIN -1 //changed @ rkoeppl 20110410
//our pin for debugging.
#define DEBUG_PIN 0
//our RS485 pins
#endif
* Sanguinololu pin assignment
#if MOTHERBOARD == 62
#define MOTHERBOARD 6
#define SANGUINOLOLU_V_1_2
#endif
#endif
#define X_DIR_PIN 21
#define X_MIN_PIN 18
#define X_MAX_PIN -2
#define Y_STEP_PIN 22
#define Y_DIR_PIN 23
#define Y_MIN_PIN 19
#define Z_STEP_PIN 3
#define Z_DIR_PIN 2
#define Z_MIN_PIN 20
#define E_DIR_PIN 0
#define LED_PIN -1
#define FAN_PIN -1
#define KILL_PIN -1
#define HEATER_0_PIN 13 // (extruder)
#ifdef SANGUINOLOLU_V_1_2
#define HEATER_1_PIN 12 // (bed)
#define X_ENABLE_PIN 14
#define Y_ENABLE_PIN 14
#define Z_ENABLE_PIN 26
#define E_ENABLE_PIN 14
#else
#define HEATER_1_PIN 14 // (bed)
#define Z_ENABLE_PIN -1
#endif
#define TEMP_0_PIN 7 // MUST USE ANALOG INPUT NUMBERING NOT DIGITAL OUTPUT NUMBERING!!!!!!!!! (pin 33 extruder)
#define TEMP_1_PIN 6 // MUST USE ANALOG INPUT NUMBERING NOT DIGITAL OUTPUT NUMBERING!!!!!!!!! (pin 34 bed)
#define SDPOWER -1
#define SDSS 31
#ifndef KNOWN_BOARD
#error Unknown MOTHERBOARD value in configuration.h
#endif
#endif
#endif
March 14, 2012 03:43AM
Use Marlin. There is a version specifically for Gen6. I tried Sprinter months ago and it did not work proper for me either...not sure if things changed or not. When I asked Kliment about it he advised me to talk with someone (can't remember the name) who had got it to work proper on the gen6 but I just gave up and went Marlin.
Try Marlin and if your problem is solved you know it is firmware...otherwise it is an electronics/wiring issue.
Marlin's acceleration has been known to default a bit too high for some so if you run into issues with skipping steps or any other issue you may have to lower the default acceleration by 1000 or so (preset to 3000).
www.Robosprout.com RepRap Mendel parts and accessories.
Message if there is anything you need...I have more than what is listed on my site.
Located in the Spokane, WA / Coeur d'Alene, ID area.
Contact: Robosprout@gmail.com Flickr: [www.flickr.com]
April 01, 2012 04:36PM
I'm having same issue any progress ?
April 05, 2012 02:44PM
Ok little update on this...
Turns out my optos where wired wrong.. I will post more info & photos later
July 02, 2012 07:33AM
It will be great to have this information because I have the same problem. Can you told us something about the wires? I bougth gen6 and the optos were wired. I'm going to change the position of the wires but I want to know first if it's going to solve the problem.
Thanks
