How do you get wide Kapton tape to adhere evenly
Posted by mchenetz
March 13, 2012 09:45PM
I have about 4" Kapton tape... What is the trick to adhering it to the bed evenly? IT seems i always have bubbles under the tape. Any help would be greatly appreciated.
Mike
Re: How do you get wide Kapton tape to adhere evenly
March 13, 2012 09:56PM
Until I tried it myself I would have thought the following advice was nuts.
Use soapy water on the glass and tape,then let dry, and its good to go.
This video is better at explaining it
[www.youtube.com];
Regards
March 14, 2012 04:34PM
If you don't want to deal with soapy water (which does work nicely, by the way), you can use a credit card as a squeegee.
March 14, 2012 05:41PM
I've never used 4" tape but with 2" tape, I just use my fingers (usually my thumb) to work the bubbles out as I'm pressing the tape on the glass or aluminum plate. So, I don't have to wait for it to dry like you do in that video.
March 14, 2012 08:38PM
March 15, 2012 08:29AM
Thanks for the replies... I am going to try some of these methods.
March 17, 2012 05:13AM
I simply take sugar water, paint it on a hot glass plate (actually a mirror tile) @100°C and print ABS on it @110°C. It works like a charm. No expensive kapton, PET or even polyetherimide. Just sugar. It smells better than the acetone/ABS coating some people are using and can be easily removed with water. As the temperature drops below 80°C after printing the parts pop off the plate.
March 17, 2012 08:08AM
One big problem with this method: ants! smiling smiley
March 17, 2012 08:20AM
Sure, in the jungle.
But if the the "reprap revolution" arrives at the jungle - any idea where to get Kapton tape there? But sugar sounds possible. smiling smiley
March 17, 2012 12:12PM
hi
take of the alum bed platform
take water with lil abit soap inside
apply water on platform and kapton tape on stiky side
place kapton tape on platform
wipe off with some robber bar or some other Straight long thing
hope this will help
