Strange Stl behavior
Posted by bdcannon
March 19, 2012 05:38PM
Hey Guys,
I was wondering if anybody has had problems with using Solidworks or Blender exported stl files. From both sources I get "Processing Failed" when I try to upload them to Netfabb. Also, when I import them into openSCAD the object gets important but it is very small, I mean like dot in the distance small. Stl objects generated by openSCAD have no problem. I was wondering if anybody knew what was up.
bdc
Re: Strange Stl behavior
March 19, 2012 05:58PM
design all my files using solidworks, no problems here
___________________________________________________
Kreativ-e
Tinkerine Studio
March 19, 2012 06:18PM
I use Solidworks too with no problems
__________________________________________________________________________
Experimenting in 3D in New Zealand
March 19, 2012 06:19PM
Check your export scale settings, you want it set to 1 stl unit == 1 mm.
-Nudel
Blog with RepRap Comic
March 19, 2012 07:56PM
March 19, 2012 11:41PM
where can i find the export scale settings in blender?
March 20, 2012 12:40AM
In blender it is in the properties menu under the scene tab. It says none (default blender units), metric and imperial. The default units (blender units) are seen by netfabb, openscad, slic3r, Skeinforge etc as millimetres.
