Idea for super smooth exterior surfaces after print wil it work?
March 23, 2012 02:47AM
I had an idea dont know if anyone thought of it yet..
here is the idea
take a pressure cooker and put it on a heating element that is thermistor controlable and a liquid with a very high boiling point and thick like molasis . then put thermistor in pot and heat to just below the melting point of whatever plastic your using bring to a high pressure .. if should become soft and the pressure should make it smooth out then just pull the piece out and smooth print..the liquid could be reussable.
VDX
Re: Idea for super smooth exterior surfaces after print wil it work?
March 23, 2012 04:04AM
... if you 'soften' the complete body, it will distort because of inner stress accumulated while cooling down when printed.
Better use a small blowtorch and heat small areas of the surface just above the melting point ... or put the part for some hours in a box with solvent-vapour ...
Viktor
March 23, 2012 05:48PM
I tried a while back using a paint/primer in one and it did a decent job of smoothing the surface, but you do end up with the finish of the paint. Use high gloss, get high gloss object afterwards. I guess it depends on what outcome you are looking for.
bdc
~Stay Calm Out There
March 24, 2012 04:39AM
lower your layer hight. lower it even more! moar!
April 06, 2012 02:33PM
To achieve a super smooth finish, just go buy some IPS Weld-on 4 and dip the part in it. 30 seconds will not affect surface detail, and longer will give the part a more glossy finish. Once you have done this, allow the part to dry overnight. It will be as smooth as you want the part to be...
April 07, 2012 05:36PM
cyanoacrylate gives a nice shiny finish to PLA.
applying it in a nice even layer could be tricky though.
