Dual Head Printing Basics?
Posted by gsport
March 28, 2012 06:54AM
So my printer seems to work really well now. Getting pretty good results and very happy with most of the results.
However I seem to want to print things that dont have a nice flat base to print from and have big overhangs etc. I have got round this a couple of times by splitting the model and printing two halves with location bobbles to re-join, but this is a bit rubbish, so I would like to try the PVA support material idea.
So I need to make a dual head extruder presumably (I am actually pretty happy with this part, I assume that the best bet is to get two hot ends as close together as possible and feed the filaments in at slight angles to keep the effective build area large)
but then I also presumably need electronics that can handle another extruder motor, heater, and thermistor and control software that can use the two heads. And a slicing program that will fill in the support material...
Is there a basic guide to this kind of stuff anywhere? Any good resources I should check out?
Thanks
George
Currently:-
Longboat Prusa (with slightly modified/fixed hot end)
Sanguilino electronics
Slic3r
Pronterface
(models from Solidworks)
Printing at 0.2 layer height typically with 0.5mm nozzle
Re: Dual Head Printing Basics?
March 28, 2012 08:21AM
You need electronics like RAMPS which support two extruders.
In Slic3r (v0.7.1) you can select a secondary extruder to do the support, but the feature is pretty new.
I have not seen a straight up guide myself but there are plenty of dual head x carriages on thingiverse.
Your best resource for dual head printing is probably #reprap IRC
-Nudel
Blog with RepRap Comic
March 28, 2012 05:27PM
Might want to check this out:
[www.thingiverse.com]
