New Linear Bearing-SMA8UU
April 03, 2012 08:36PM
I found these bearings on Zapp, looks pretty interesting for the Y axis on a Prusa/Mendel, you could bolt them directly to the bottom of your Y carriage. And very cheap at only £4.00! It says they contain a LM8UU bearing inside them too, maybe you could pull it out for use on the X and Z axes.
[www.zappautomation.co.uk]
Re: New Linear Bearing-SMA8UU
April 04, 2012 09:14AM
Much better than the price I used on my senior design project at college! It was a laser scanner system to measure thread pitch and form of a die that cuts threads into bolts. Only about 12K for the system smiling smiley But these were the bearings we used
[www.mcmaster.com]
Ryan
Quality Engineer & Hobbyist
thingsandtrains.blogspot.com
April 04, 2012 07:43PM
Wow, for some reason I thought that normal LM8UUs were ~$10 a piece. Just looked, found them in packs of 10 for $20. These don't look like such a great deal anymore.
April 10, 2012 02:34AM
Why pay for something you can print?
April 10, 2012 03:26AM
I find bearings last and are 1000 times smoother in operation than any printed bushing
__________________________________________________________________________
Experimenting in 3D in New Zealand
April 10, 2012 08:58AM
I'm guessing he meant the block that the bearing was in, not the bearing itself. And we could definitely print that block.
April 10, 2012 12:38PM
Why buy linear bearings when you can print them : [www.thingiverse.com]
Well, I don't know about durability, the printer is in construction right now, but it slide smoothly.
April 11, 2012 05:15AM
> smoothly.
That's probably more down to the quality of your rods: [hydraraptor.blogspot.co.uk]
April 11, 2012 09:03AM
I had to laugh pretty hard when i saw this
Machined ballscrew with C7 precision? hahahahahaah, no way! it's a rolled ballscrew
VDX
April 11, 2012 09:50AM
... it's somehow misleading - only the ends are machined spinning smiley sticking its tongue out
Viktor
April 11, 2012 10:10AM
Yes I think it means the ends are machined and the screw has accuracy C7, which is nothing special.
January 12, 2013 05:02PM
Shardbearer,
Where did you find the LM8UU bearings for $20 per 10 pack? Thanks.
randy
