Temperature vs. Print Quality (ABS) April 05, 2012 10:47PM |
Re: Temperature vs. Print Quality (ABS) April 06, 2012 10:41AM |
Re: Temperature vs. Print Quality (ABS) April 06, 2012 02:51PM |
Re: Temperature vs. Print Quality (ABS) April 08, 2012 03:08PM |
Re: Temperature vs. Print Quality (ABS) October 18, 2014 10:42AM |
Old thread I know but I just bought some filament as I was on the same 1kg for 7 or 8 months (no where near out either) and I will say you are right.Quote
C. Cecil
Not only have different ABS batches had different melt temps for me but also different colors. Every color seems to want a different setting. I range between 200 and 225C for all my ABS.
Re: Temperature vs. Print Quality (ABS) November 04, 2017 09:45PM |
Re: Temperature vs. Print Quality (ABS) November 04, 2017 11:02PM |
I never did finish the KBell spool as it is pure junk (would no longer stick to itself and was really too brittle but wasn't pure ABS if much ABS to it) and they went out of business so good riddance.Quote
Bokem44
30 yrs in the plastics industry and I can tell you that colorants do affect material properties. Also, different manufacturers use different additives which account for many of the variations seen between brands. On another note, thermistors (and heaters) should be seated, contacting the metal block of the hot end to get the best results. Measuring or heating an air pocket or gap is quite inconsistent.
Re: Temperature vs. Print Quality (ABS) November 08, 2017 01:46PM |
Re: Temperature vs. Print Quality (ABS) November 08, 2017 05:49PM |
I agree but I don't know of a knock-off hot end that uses a thermocoupler and I have no idea how to hook one up to a Ramps 1.4 either. Probably not hard just never looked it up since I have no need to buy an 80 dollar real E3D just to be able to use a Thermocoupler.Quote
DjDemonD
I think so long as you try to determine as best you can what the temp you see indicated actually is really at the nozzle, I use a K type thermocouple and heatsink paste and place the sensor on the nozzle then measure a few select temperatures that are often used 200,220,250 etc..when setting up.
Or switch to a pt100 sensor which are far more accurate.
The other implication of temperature is that interlayer bonding is better at higher temperatures even if stringing is worse and parts look melted.
Re: Temperature vs. Print Quality (ABS) November 08, 2017 05:51PM |
Re: Temperature vs. Print Quality (ABS) November 08, 2017 06:53PM |
I should have added that I am still not convinced a thermocoupler matters for temps below 300c which is as far as I would attempt a thermistor. I just haven't seen a compelling reason to switch beyond the "it is something new" boat.Quote
DjDemonD
You can buy Chinese hotend heater blocks with cartridge style temperature probes, and you can buy themocouples/pt100 and the amplifier boards required from China also. I bought 1 e3d pt100 for £12 and 3 from china for £8 but I dont know if the cheap ones will work as well.
But it doesn't matter I have a multimeter with a thermocouple so I use it to check my thermistor table/values are right.
Re: Temperature vs. Print Quality (ABS) November 09, 2017 11:41AM |
Re: Temperature vs. Print Quality (ABS) February 11, 2018 11:39AM |
