I've gone from a 0.5mm nozzle to a 0.3mm.Haven't tried a print yet with the new nozzle.
Which software/firmware setting(s) do I need to change?
Thanks in advance.
Mike
Re: Moved to 0.3mm nozzle size - what software settings to change?
April 08, 2012 05:47AM
you should only need to change it in slic3r or whatever.
since extrusion steps is done on filament input rather than output.
April 08, 2012 07:09AM
But remember to measure the output filament: you need to put in the software the actual width of extruded filament and not the size of the nozzle (ie: my 0.5mm nozzle is giving me a 0.7mm extruded ABS filament).
April 08, 2012 02:18PM
> ABS filament).
psht, use slic3r it works it out automaticaly.
April 08, 2012 04:53PM
If using Skeinforge, the main settings you'll need to change are:
Carve: Edge width over height (1.5), layer thickness (0.3) instead of 0.4 for the 0.5mm nozzle.
Inset: Infill width over thickness (1.5)
these should improve your print quality significantly but I found that I had to calibrate other settings to get the best out of the change.
