RepRap motherboard to an AC servo motor and driver July 03, 2010 08:35AM |
Re: RepRap motherboard to an AC servo motor and driver July 05, 2010 05:34AM |
Re: RepRap motherboard to an AC servo motor and driver July 05, 2010 05:36AM |
Re: RepRap motherboard to an AC servo motor and driver July 05, 2010 08:32AM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: RepRap motherboard to an AC servo motor and driver July 05, 2010 09:09AM |
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: RepRap motherboard to an AC servo motor and driver July 07, 2010 06:53PM |
Wikipedia
Two-phase AC servo motors
A typical two-phase AC servo-motor has a squirrel cage rotor and a field consisting of two windings:
1. a constant-voltage (AC) main winding.
2. a control-voltage (AC) winding in quadrature (ie, 90 degrees phase shifted) with the main winding so as to produce a rotating magnetic field. Reversing phase makes the motor reverse.
An AC servo amplifier, a linear power amplifier, feeds the control winding. The electrical resistance of the rotor is made high intentionally so that the speed/torque curve is fairly linear. Two-phase servo motors are inherently high-speed, low-torque devices, heavily geared down to drive the load.
[edit]
Re: RepRap motherboard to an AC servo motor and driver July 07, 2010 10:15PM |
Re: RepRap motherboard to an AC servo motor and driver July 08, 2010 04:28PM |
Re: RepRap motherboard to an AC servo motor and driver July 08, 2010 09:52PM |
