Hi to all on the forum,
In case anyone is interested, please see attached some tweaked extruders with larger fittings for the thermal barrier. This was done as to reduce lathe work as the tip would need to be turned down at the top to fit.
Big shout to Greg Frost as this is a variation of the v6 extruder he designed.
These have been repaired in Netfabb so should be good to go.
Thanks,
Raj
open |
download -
WadesExreuder15mm1 (repaired).stl
(183.8 KB)
open |
download -
WadesExreuder16mm (repaired).stl
(164.1 KB)
