hacking a PCB milling machine to become a boot strap
Posted by tangsob
July 22, 2010 09:15PM
Dear all,
as I am currently in China I think about buying this PCB milling machine and modify it to become a boot strap machine.
[item.taobao.com]
I plan to keep the 4 pol stepper motors, but replace the complete electronics and also add the opto end stops. Of course I would also need the extruder, but mechanical fixation seems to be easy to realize.
What I am affraid of are the needed software adjustments for machine calibration. Could such a spindle drive with shaft joints be accurately controlled by the software? I probably would need add some code and compile it again, right?
Please just help me to give a general estimation of feasability.
Thanks in advance! Grettings from the middle kingdom,
Peter
Re: hacking a PCB milling machine to become a boot strap
July 23, 2010 04:42AM
Sounds like a good plan. You might want to keep the Stepper Motor Drivers as well and replace the central computing unit only.
Yes, you'd have to adjust firmware settings for your mechanics. A step RepRap's firmware is well prepared for. (Re-)compilation is also a commodity, as there doesn't even exist a binary distribution. Everybody is compiling, and it's only a matter of installing the Arduino IDE plus code download plus a few clicks: [reprap.org]
July 24, 2010 12:08AM
Peter, where in china?
Asia RepRap User Groups
A few other questions:
1: What's the vertical clearance of that machine?
2: Are you buying anything from our Official RepRap-China Supplier™
3: What are the fastest traverses you can get with that machine?
4: Have you thought about a WolfStrap?
5: Does it use unipolar or bipolar stepper motors?
-Sebastien, RepRap.org library gnome.
Remember, you're all RepRap developers (once you've joined the super-secret developer mailing list), and the wiki, RepRap.org, [reprap.org] is for everyone and everything! grinning smiley
July 24, 2010 01:15AM
I am located close to Shanghai in Nanjing.
75mm. Maybe 65 mm with endstops. Should be enough for all mendel parts, right?
I also saw this offer, but decided to save some money. winking smiley
> that machine?
Good question. Haven't thought about this. After online research for typical machines like this I would say up to 15mm/s. But I will check with the persons who sells the milling machine and give a more accurate value later. What is the minimum usable axis speed for printing? Is the quality increasing or decreasing with slower speeds? I am also worried that the complete different acceleration and deceleration characteristics might cause problems.
Yes! If it is not possible to hack the milling machine, I would probably go for a solution like that.
The motor controller shows 4pins. So they are bipolar.
February 27, 2011 03:59PM
Hey everyone. Digged out this old post to share with you that I did it. It slow like hell, but tomorrow I will have my meshball print finished... MUHAHAHA
check out my just started blog (photo album): http://tangsob.blogspot.com/
February 28, 2011 06:58AM
Looks real good Tang. Congratulations!
