Graphene abs/pla mixes
Posted by BowHendy
April 25, 2012 03:26AM
Hi community,
Has any one looked in to blending graphene & abs/pla polymers?
I've only had a surface look but a 1% mix is enough to make plastics conductive then its worth considering.
Will return with a more informed understanding.
B
Edited 1 time(s). Last edit at 04/25/2012 03:31AM by BowHendy.
VDX
Re: Grapheme abs/pla mixes
April 25, 2012 03:31AM
... graphene is essentially the basis of graphite - but purified and with bigger 'flakes', so much more expensive eye rolling smiley
You should check for specs of graphite-blends as comparison ...
Viktor
Re: Graphene abs/pla mixes
April 25, 2012 04:03AM
Hi Viktor,
I wonder are you also reading the papers on the way to worksmiling smiley
While I am sure I am over looking many details I found this information in earlier thread which involved using a DVD drive to convert graphite oxide in to grapheme.
[m.youtube.com]
My thinking is whether a base material can be mixed with abs / pla extruded, then converted via a laser tool as a secondary step?
Edited 2 time(s). Last edit at 04/25/2012 04:41AM by BowHendy.
VDX
April 25, 2012 04:53AM
... check also for MID (Moulded Interconnect Devices) ald LDS (Laser Direct Structuring).
Here plastics are blended with some additives, that remain non-conductive after moulding/extruding, but will change to conductive when 'activated' with a laser (or galvanically coated with metal in a second step)
Viktor
VDX
April 25, 2012 05:01AM
... here are some samples and specs to 3D-MID and LDS (only German)
Edited 1 time(s). Last edit at 04/25/2012 05:02AM by VDX.
Viktor
April 25, 2012 07:01AM
Thanks victor,
Looks like I might need some lasers & graphite variants so a visit to dealsextreme & alibaba's is in order. smiling smiley
I'll keep the thread posted with my progress.
VDX
April 25, 2012 07:20AM
... if you search high-power IR-laserdiodes, i have some tens of 5Watt- and 9Watt-diodes with 957nm and attached fiber salvaged from broken fiber laser pumps - look here for some hints: [objects.reprap.org]
Viktor
