yngndrw Wrote:
> miro87043 Wrote:
> > Is it realy a bad idea to adjust pots while the
> > machine is on? I do that regularly while
> setting
> > up my printers. What's the worst that could
> happen
> > if doing this?
> It jumps as you turn it and you end up driving it
> with way too much current, or you slip and short
> something out.
Okay. I had considered the slip and short, but I did not realize the current would spike. It's my guess that a short spike isn't likely to warm up the winding enough to cause damage, but it's probably not worth the risk.
I'm curious if anybody has actually damaged there stepppers by adjusting there pots while powered up.
