Prusa BOM up to date (rod length)
Posted by AndrewD
August 10, 2011 05:04AM
I'm placing an order for stainless rod and threaded, but I thought the spec had changed on one of the lengths?
There is no update history on the wiki BOM, so I don't know if I'm ordering the correct cutting list...
I'm using [reprap.org]
Andrew
Based in Slough, United Kingdom
Re: Prusa BOM up to date (rod length)
August 13, 2011 02:04AM
Are you thinking of the alternate X mounts for the original Mendel? It uses the shorter X travel smooth rods.
http://reprap.org/wiki/Mendel_Alternate_X_Motor_Bracket
As far as I know, that does not apply to the latest Prusa BOM. The wiki is current.
Edited 1 time(s). Last edit at 08/13/2011 02:05AM by TheCase.
August 13, 2011 02:17AM
I think the Prusa x rods used to be 495mm, but the page you linked to shows the newer (adjusted) figure of 420mm.
I've cut mine to 420 - I hope it's right!
August 13, 2011 02:24AM
> figure of 420mm.
Yup that's what I thought, but there was no revision trail on the WiKi, stainless A2 rod and threaded ordered, I can go ahead and send the cutting list now!spinning smiley sticking its tongue out
Andrew
August 13, 2011 02:26AM
420mm for the longest smooth (x2) is correct
