Stratasys's mojo : throw-away hotends May 10, 2012 04:17AM |
Re: Stratasys's mojo : throw-away hotends May 10, 2012 02:23PM |
Re: Stratasys's mojo : throw-away hotends May 10, 2012 05:25PM |
Re: Stratasys's mojo : throw-away hotends May 10, 2012 05:30PM |
Re: Stratasys's mojo : throw-away hotends May 10, 2012 08:00PM |
Re: Stratasys's mojo : throw-away hotends May 11, 2012 01:24AM |
Re: Stratasys's mojo : throw-away hotends May 11, 2012 01:31AM |
The article
Only solid printing is permitted, ensuring very strong printed parts, but also using more material. The software does not provide an option to select a density percentage.
Re: Stratasys's mojo : throw-away hotends May 11, 2012 06:06PM |
Re: Stratasys's mojo : throw-away hotends May 11, 2012 06:53PM |
Re: Stratasys's mojo : throw-away hotends May 11, 2012 07:45PM |
Re: Stratasys's mojo : throw-away hotends May 11, 2012 09:27PM |
Re: Stratasys's mojo : throw-away hotends May 13, 2012 09:20AM |
Re: Stratasys's mojo : throw-away hotends May 13, 2012 10:59AM |
Re: Stratasys's mojo : throw-away hotends May 13, 2012 12:31PM |
Re: Stratasys's mojo : throw-away hotends May 15, 2012 03:12PM |
Anonymous User
Re: Stratasys's mojo : throw-away hotends May 15, 2012 07:10PM |
Re: Stratasys's mojo : throw-away hotends May 15, 2012 07:58PM |
FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Anonymous User
Re: Stratasys's mojo : throw-away hotends May 16, 2012 12:38PM |
Re: Stratasys's mojo : throw-away hotends May 16, 2012 01:05PM |
Re: Stratasys's mojo : throw-away hotends May 16, 2012 01:53PM |
Re: Stratasys's mojo : throw-away hotends May 16, 2012 02:10PM |
Re: Stratasys's mojo : throw-away hotends May 16, 2012 05:17PM |
Re: Stratasys's mojo : throw-away hotends May 17, 2012 01:33AM |
Re: Stratasys's mojo : throw-away hotends May 17, 2012 02:28PM |
Re: Stratasys's mojo : throw-away hotends May 17, 2012 02:35PM |
Re: Stratasys's mojo : throw-away hotends May 27, 2012 01:08AM |
Bertho Boman
Following the usual trend, “low-cost” printer and custom ink, this model has taken it a step further: A cartridge filament system interlocked with a throw-away print head. The design makes it convenient though, just drop in a cartridge and snap a head in place and go.
As can be seen in the first picture, there is a filament cartridge on each side and two blue print heads in the center. There is a sample head the left side. The heads just snap in place like loading an inkjet cartridge.
The strange black boxes at the rear corners triggered several questions in previous posts. They are simple mechanical retainers to keep the feeder tubes in place. There is a little blue ring on the tubes that snaps in place and it just locks it in position. I asked the design engineer and was told it is a prototype and they will simplify it. The whole top of the machine is actually a 3D print for the prototype.
The inside of the machine can be seen in the second picture. It has a usual heated build chamber. Note the big blower in the back with a wide horizontal slot near the top. The two white rectangular objects in the top center are the print head tips. They have what appears to be a silicone rubber cover.
The most intriguing part to me is the head design. It is extremely small!! Besides the thermal heater function it also has the drive circuit inside that small case. I managed to get an opportunity to look inside it. It is very nicely made, considering it is a throw away item.
· The filament is non-standard size: 1.3mm
· The drive motor is a low-cost brushed DC motor with what appears to be a simple magnetic encoder
· The motor is geared down with a worm-gear.
· The heater with the thermocouple is extremely small, about 6mm in diameter.
· There is a small PCB with an IC on it and a few extra components. Presumably it is the interface for the thermocouple, the shaft encoder, and I would guess an internal serial number to prevent reuse if someone manage to find filament that would fit.
Re: Stratasys's mojo : throw-away hotends May 27, 2012 02:29AM |
Re: Stratasys's mojo : throw-away hotends August 25, 2012 01:25PM |
Re: Stratasys's mojo : throw-away hotends August 25, 2012 04:03PM |
Re: Stratasys's mojo : throw-away hotends August 25, 2012 04:49PM |
