Loading Filament
Posted by N314
Loading Filament
May 15, 2012 07:58PM
How do load filament?!? I can never seen to get filament to load right. Is there a secret? Im using wades extruder with 1.75mm Filament.
-Nick
Re: Loading Filament
May 15, 2012 11:46PM
What hotend are you using?
bdc
~Stay Calm Out There
May 16, 2012 05:51AM
print and install gregstruder
then when you want to change filament,
1) slacken idler
2) heat hot-end to Tg+5c (Tg is 60c for PLA, 105c for ABS)
3) wait for it to overshoot, then pull filament firmly but slowly
4) typical results look like this or this or this
5) cut point on end of new filament
6) insert new filament
7) re-tighten idler
8) heat & purge
9) print
Wooden Mendel
Teacup Firmware
May 16, 2012 08:17AM
I get by with only step 5), and no tightening or adjustments. Just make sure you cut it at a steep angle, and in the right direction so it feeds easily through the hobbed bolt and cold end. I do this with 90% reliability, and can do it while printing.
-Nudel
Blog with RepRap Comic
