I wanted to try a bowden extruder system for my 2nd Reprap. I was reading about the different designs for the bowden cables and hot-ends and read that some people have trouble with the connection of the bowden cable to the extruder and hotend.
At my job i work with high pressurized gasses (for greenhouse gas emmision research), there we always use Swagelok components for all the hook-ups of the gas tanks to our machines. Swagelok has really good quality stuff, but it is also very expensive.
Here my setup:
i mounted a 1/4" union into the extruder, to this i attach the bowden cable (1/4") with on both sides a Swagelok nut and ferrules. The x-carriage is fitted with a 1/4" bulkhead union, to which on one side the bowden cable is attached and on the other side the hot-end (own design with 1/4" stainless steel tube, so the 1/4" swagelok fittings work great). See: [
www.reprap.org]
Both the bowden cable and the hot-end can be mounted or replaced with just one solid nut.
See the pictures at:
www.flickr.com]
www.flickr.com]
www.flickr.com]
Maybe this is an idea for the shops?
i hope to get some comments.
Edited 1 time(s). Last edit at 04/03/2012 12:30AM by north90ty.
