Motor test Problem
Posted by N314
Motor test Problem
May 03, 2012 08:19PM
Hi-
I plugged in my electronics and tried to get a motor to move. When I plug the motor into X and E0, they make a slight hum... tell it to move, nothing happens. I plug it into Y and Z... No sound or movement. How do i make them work?
RAMPS 1.4, Pronterface
-Nick
Re: Motor test Problem
May 03, 2012 08:28PM
Do they "lockup" (i.e. become difficult to turn by hand) when you plug them in?
How do you have them wired?
How are the pots on the drivers set?
May 03, 2012 08:36PM
1. X axis and Extruder do.
2. Is there a certain way to. I have tried both ways.
3. I experimented with the X pot to no avail.
-Nick
May 03, 2012 09:59PM
do you have end stops plugged in?
__________________________________________________________________________
Experimenting in 3D in New Zealand
May 03, 2012 10:07PM
No
-Nick
VDX
May 04, 2012 02:56AM
... add endstops or invert or deactivate them in the firmware ... and don't plug/unplug the motors with powered drivers, or the drivers will blow!
Viktor
May 04, 2012 10:05PM
I connected everything, then powered up. I had an endstop on X. I did a test print and nothing. With a voltmeter ive found theres voltage (but no action) on X and Extruder... No voltage on Y and Z.
What can I do?
-Nick
May 04, 2012 10:27PM
Now weird things are happening.
I connected all motors. Endstop on X. Powered up. Clicked move on X and the extruder motor started moving. Also No other motors will work.
What am I supposed to do... I'm so confused.
-Nick
May 05, 2012 04:13AM
Seems like you firmware is configured for a different board.
May 05, 2012 04:14AM
If the extruder is moving when you try to move X, then either you have the motor plugged into the wrong stepper driver, or you have the wrong pin assignments set in firmware.
May 05, 2012 10:37AM
How do I change the Firmware?
May 05, 2012 08:36PM
Ok...
I switched to Marlin firmware and things are working better. They are still a bit sketchy, but I think I can make it work.
Thanks for all the help,
-Nick
May 08, 2012 06:15AM
I did that few days ago and it worked so no problem.
