Switching from PLA to ABS May 20, 2012 08:02PM |
Re: Switching from PLA to ABS May 21, 2012 02:37AM |
My heated bed can only go up to 70C with a piece of glass on top, will this be hot enough?
Do I need to cover my glass with Kepton tape? When removing the prints, do the parts stick too well that I might break the glass?
I have cooling fan for printing PLA, mainly because I am printing at high speed.. Do I need to use fan for ABS too?
Re: Switching from PLA to ABS May 21, 2012 03:54PM |
Re: Switching from PLA to ABS May 21, 2012 06:55PM |
Re: Switching from PLA to ABS May 22, 2012 02:07AM |
With the underside, I am using tin foil in oven bag and a piece of thin wood at the bottom.
Do you think ABS is trickier to print compared to PLA?
Another question, what happens when I want to change PLA filament to ABS and vice versa. Do I need to ooze out all existing PLA or just pull out the filament? What happens when PLA and ABS got mixed together inside the hotend??
Re: Switching from PLA to ABS May 22, 2012 02:33AM |
i am thinking of making another parallel circuit of nichrome wires which is connected in series to the existing one.. and hope it can double the output.. confused smiley
Re: Switching from PLA to ABS May 22, 2012 02:03PM |
Re: Switching from PLA to ABS May 22, 2012 06:55PM |
