stl file problems
Posted by richardjrussell
stl file problems
May 21, 2012 12:29AM
I tried using a plugin (cadspan) with Google Sketchup to create a part and turn it into a stl file to run on my printer. I'm not having any success. Can someone tell me step by step how they are doing this? Thank you!
Re: stl file problems
May 21, 2012 11:45AM
I had issues exporting STL files as well. What I ended up doing is when you hit export stl file, I had to type the filename.stl If I just entered the "filename" it wouldnt work and didnt automatically put the stl extension. For example save 20mmCube and it didnt work. But if I saved 20mmCube.stl it would work.
Hopefully your's is the same issue and that fixes it!
Ryan
Quality Engineer & Hobbyist
thingsandtrains.blogspot.com
May 21, 2012 07:49PM
sad part is that sketchup is no longer google's they sold it to another company, i hope they keep it the way it is at least. but i ended up having to add the .stl too with my plugin i forget what one. but even if you dont add it you can do it after in windows under rename.
[mike-mack.blogspot.com]
Anonymous User
May 21, 2012 08:07PM
May 23, 2012 03:18AM
Arrg!
I gave it a try and I get the same message.
IndexError: list index out of range
May 23, 2012 03:44AM
Can you open the files in Netfabb basic? if so use that to resave the files and see what happens, it might even pay to do a repair while they are in Netfabb
__________________________________________________________________________
Experimenting in 3D in New Zealand
