Z-axis Issue?
Posted by Zimtower
Z-axis Issue?
June 26, 2012 07:49AM
Is this what I think it is? This is my 5th attempt at printing btw.
Re: Z-axis Issue?
June 26, 2012 09:42AM
If the ridges match the threads on the threaded rod on z, it could be the rod is not straight and is pulling the entire x gantry out of position.
Lube.
Check/adjust z couplings and trapped nuts.
Exchange bent z rod for a higher quality (=probably straigher) stainless steel rod.
Cool print though, my nieces would love that! smiling smiley
Edited 1 time(s). Last edit at 06/26/2012 09:44AM by Nudel.
-Nudel
Blog with RepRap Comic
Re: Z-axis Issue?
June 27, 2012 09:15PM
This is likely Z_Axis wobble.
Show a picture of your printer, and it will help identify the culprit.
Usual suspects are captive z-motors (screwed down), captive lead screws (either by using two sets of nuts in the x-motor/idler ends, or using the printed 608 bearing holders at the top or bottom of the rods, or bent rods.
Re: Z-axis Issue?
June 28, 2012 06:39AM
My z-axis threaded rods were slightly bent. I got some silver coated rods in the mail, gonna install tommorow and see what I have.
Re: Z-axis Issue?
June 29, 2012 06:47AM
I just installed these very straight threaded rods and there is a tiny amount of improvement. I am also using the spiral couplers which I hear can be self-defeating.
[www.thingiverse.com]
I am guessing I should print these out?
Re: Z-axis Issue?
June 29, 2012 10:10AM
"....or using the printed 608 bearing holders at the top or bottom of the rods, or bent rods"
So the bottom of the threaded rod on a standard prusa should not go through this bearing holder attached to the base, but rather just float in the air?
Re: Z-axis Issue?
June 29, 2012 10:15AM
There is no base on a standard Prusa. Yes the rods dangle from the motor.
Re: Z-axis Issue?
June 29, 2012 12:17PM
Helical flex coupling are meant to be used in situations where you have a captive rod and captive motor. The coupling then allows there to be misalignment without placing stress on the bearings.
In the case of repraps, the ideal solution would be a motor with a threaded shaft, but these are expensive.
Almost any solution will produce good results IF the mating of the rod to the motor is concentric, and the rod is straight.
