Ideal temperature and Humidity
Posted by 3Der
June 27, 2012 01:33PM
Hello all,
what is the ideal temperature and humidity for 3d printing? Also anything I should need to know that may affect the print? Also a 3d printer printing right next to an airconditioner doesn't ruin the print right?
Re: Ideal temperature and Humidity
June 27, 2012 01:41PM
People report both very varied temperatures an humidity, as far as I have seen.
High moisture will - over time - damage your filament. Especially PLA sucks up a lot of moisture, and it will be difficult to print nice with. This can take months though, so if you keep your filament in an airtight box or sealed plastic bag when you're not using it, you should be good.
Low temperatures are not that important when you use a heated bed, but having your printer next to a window when there's a high difference in outside and inside temperature, can make one side of your printer colder than the other, and lead to warping.
High temperatures means you might have to add fans to cool down the electronics, which is a good idea for longevity anyway.
Airflow from an A/C unit can be difficult if it's very powerful, as it can make the bed struggle to keep the temperature stable, leading to warping.
Most of this things can be fixed by either increasing or lowering the print and/or bed temperature. Or you can make a cardboard shield to protect your printer.
-Nudel
Blog with RepRap Comic
June 29, 2012 01:31PM
If you printing with ABS and heat bed then airconditioner should be turned off also at winter ABS printing is not so good as at summer.
Regards.
www.gadgets3d.com - parts for your 3D printer.
