edit: from what i see SSR-R05DD Solid State Relay. these are dc/dc relays. Turn Off Voltageļ¼<3.0VDC
it seems like these will work, be sure to use at least 100 ohm resistance from Sanguinololu to relay in case of failure or capacitive spikes in current to protect i/o pin.The only issue i see is damage from static charge building up. perhaps place a 10k from ground pin to relay input and a 10k resister in parallel across load, in case load ever becomes disconnected.
Edited 1 time(s). Last edit at 07/04/2012 01:00PM by jamesdanielv.
